Home > Maintenance & Mods (L322) > Disaster Oil Change! 4.2 SC |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35337 |
oil's well then ... - .- -.
12th Jul 2017 7:53pm |
buffalo4 Member Since: 01 May 2016 Location: Doncaster Posts: 143 |
you've bin (bagged ) and done it |
12th Jul 2017 8:13pm |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
exactly my point.. which is why we see more and more examples of garages and users pumping the oil out rather than drain through sump plug which is a bad practice.
12th Jul 2017 9:49pm |
rkaad Member Since: 10 Jan 2012 Location: London Posts: 12 |
This https://www.fumotooildrainvalve.com/ might help. Have had one on the landcruiser for years...contemplating one for the RR. |
12th Jul 2017 11:16pm |
I like the idea and concernwd that of it faila you could be running the car with no oil. Imagine that.. Id be paranoid all the time.. besides how would these work with RRs as the drain plug is pointing towards the front driver side? Current:
12th Jul 2017 11:37pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 739 |
Could use a vacuum pump then if you are worried about what's left in the sump then take the drain plug/s out - there's only a dribble to worry about then |
13th Jul 2017 6:41am |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
We started using a pump now, is so satisfying when you remove the drain plug and only a little trickle comes out!
13th Jul 2017 8:20am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
cass is right, vacuum than drain the rest (very little) oil. However if you wanna have real slick solution "if someone could invent a solution he will be a godfather" 4.4TDV8 engine designers have done exactly that. pipe that you disconnect to drain the oil in 4.4TDV8 is the same pipe you use to vacuum extract the oil. this engine does have second drain plug which is used to drain turbo oil pickup pocket-holds about 3~4 dcl oil. i change my oil in 5k km. intervals and drain secondary oil plug every other oil change.
13th Jul 2017 10:48am |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
any idea which one for FFR TdV8 ? they dont list land rover |
13th Jul 2017 6:26pm |
I feel nervous with this.. imagine the valve fails and next minute you have a seized engine.. Current:
13th Jul 2017 8:32pm |
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 |
Looks like the Fomoto valve locks so can't come undone, I'd buy one, but as said doesn't list Land Rover.
14th Jul 2017 7:14am |
http://www.quickvalve.co.uk/ lists Landrover[/url] |
14th Jul 2017 7:22am |
Good find mate.. below are the options available. Im thinking we may need an extension but that would further push it towards the frame..
14th Jul 2017 7:31am |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
Same situation if a sump plug is not done up properly, but can see where you are coming from as sump plugs are a bit more tried and tested and also the norm. cheers Alex 2018 Skoda Kodiaq vRS 2009 Caterham Supersport Race car 2007 M5 Touring 2005 Range Rover Vogue SE Supercharged 2004 SL55 AMG |
14th Jul 2017 9:06am |
