Home > Technical (L322) > engine cut out
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
engine cut out
Hi all I'm in need of technical assistance my fatty ground to a halt on the coming home from B&Q. The engine cut out and a fault on the display panel came up FUEL INJECTION SYSTEM to my horror it wouldn't restart i had my IID tool to hand plugged it in and this is what it came back with-
1 0xp1180-04 low side fuel pressure sensor plausibility (fuel Filter) - pre delivery pressure below starting required
2 0xp0401-20 extended fault [path exhaust gas regulation governor deviation negative
3 unknown
I cleared the faults and she started up ok and drove home.
Has anyone had this before and any ideas please Big Cry Bow down
Post #444374 12th Jul 2017 6:36pm
Simran0211
update on engine cut out
I have read up on 47p2 experance and followed suite and have managed to get one for £35.96 from a motor factors Very Happy and all is well back on the road many thanks for 47p2 for his write up Bow down
Post #444456 13th Jul 2017 11:13am
was it the fuel pump? ... - .- -.
Post #444457 13th Jul 2017 11:31am
Simran0211
Update
And yes it looks like I have sorted the problem and I can also hear the pump as I couldn't before although the pump looks like it been changed before only time will tell if I have firm solve the problem Thumbs Up
Post #444462 13th Jul 2017 1:25pm
Simran0211
No stan I was wrong it's back to its normal tricks same code but I can hear the secondary pump purring away I have replaced the fuel filter this afternoon and took the fuel pipe off to see if there is any fuel coming out to my surprise NOTHING the only thing I can think of now is replacing the main pump in the fuel tank has anyone any other ideas please Big Cry
Post #444543 14th Jul 2017 8:57am
