![]() | Home > Maintenance & Mods (L322) > antifreeze |
Are you going to do a full change? You can use any AF in there - as long as you dont mix. To be on the safe side you could drain and fill with plain water - run for a few mins and drain again, then fill with correct mix of your choice. Make sure you use something you have readily available so you dont need to flush again next time though. ![]() |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
To be honest i was going to be lazy and siphon out a litre and top up with some neat. Too cold to be playing with cars at the moment so it was going on the list for spring. Might just be safer to leave it as should be fine @ -17 in the south east. Is draining down and re-filling\bleeding a straight forward job on a range rover, seems to read that way in rave. 2004 black Vogue TD6 |
Its a yearly service task - so generally strait forward. |
yearly... ![]() i wouldn't bet againsts mine still running its original stuff. 2004 black Vogue TD6 |
Manual suggests 2 years - however the corrosion inhibitor is generally useless after 1. And you don't want silting in the lower portions of the rad. It costs about £20 to change the coolant, so is a very cheap maintenance job and considering the importance of a healthy cooling system I'm surprised it often gets overlooked. ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
ok, a nob question, why cant you mix?.. ... - .- -.
From Rave;
dont know the chemistry but i have been advised not to mix different types of antifreeze as it could turn to sludge. 2004 black Vogue TD6 |
Mines is not due a service till June think i might stick it into a local Garage to do a Flush and re-fill ..... |
There are two types of anti-freeze, and they are two that must not be mixed as the Organic stuff turns to sludge within a few days if mixed. Ethylene glycol based anti-freeze - This is Blue or Green Organic acid technology - This is Orange, Red or Pink OAT (sepcifically DEXCOOL) has been linked with HG failure and has resulted in large payouts in the US, obviously over here that wouldnt happen. Regardless of what the instructions say on the back of the bottle you CANNOT interchange these two types. The problem comes when you dont know the history of your cooling system. Manufacturers prefer OAT due to the longer life between changes, personally I'd rather not risk complete engine failure for the sake of a few quid. What you have to remember though is that Land Rover WOULD rather risk engine failure (after warranty) for the sake of a few quid. Dan ![]() |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
In my day, it was a hosepipe in the top of the rad to flush engines out! Probably changed now.... 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Mick - IIRC most Land Rover service agents offer "Pre-winter" checks for a small fee, they look over the car, top up the screen wash at their hugely inflated price, check the wiper blades, tyre condition and check the coolant that it is the right density and drain/top-up as required.
