![]() | Home > Maintenance & Mods (L322) > Replacing Rear Hub Bushes - How To |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Probably best to get the hub in "wheel on position" before tightening up, under load. .
DoubleRL322 Member Since: 05 Jul 2016 Location: Orlando, FL Posts: 25 ![]() ![]() ![]() |
Ok meaning leave the jack supporting the lower control arm or not? |
Yes, but jack to "wheel on" position so in effect taking the load of the car. .
johnc10 Member Since: 25 Mar 2012 Location: England Posts: 1 ![]() ![]() |
Excellent write up. I've just done mine exactly as you have shown. I used the Laser tools but your kit is better and cheaper. My height sensor rubbers had perished so replaced sensors too. I got a hub kit off ebay with bushes, bolts and washers, �90. |
andyfid Member Since: 10 Apr 2016 Location: barnsley Posts: 104 ![]() ![]() ![]() |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Just did mine this weekend, write up is really helpful.
![]() That's my 5ft long commercial torque wrench with me (90kg) on the end. The Snap On windy gun wouldn't touch it! Cheers, Paul 2011 TDV8 AB 2006 TD6 AB (Gone to Wales) |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1558 ![]() ![]() |
I'm doing mine on Monday. I've hired the correct tools (made by Laser Tools) from a fellow member of the AULRO forum. Ron B. VK2OTC
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 ![]() ![]() ![]() |
I must of been lucky as I’m doing a rear wheel bearing I pushed the bushes out with my 12 tonne press came out easily for once. |
But that would require taking the lower arm off the car and over to the press. I admit that is my preferred option, but with the lower knuckle on the lower suspension arm that is more hasle than trying to get the bush out in situ I think.....?
A friend and I replaced the rear upper and lower bushes last Monday.
Marked to get the eccentric washer back in approximately thh right place. (The car is having a wheel alignment done as I write.)
Quite easy when one uses the right tools and have access to a hoist. I used the LaserTools http://www.lasertools.co.uk/product/5977 and http://www.lasertools.co.uk/product/5978
The bushes had little to no radial play but quite a bit of axial play, especially the left lower where the play was about 1.5mm. The grease was old and hard and there was a bit of rust in the joint. The left lower also has two pieces of thin plastic (nylon?) jutting out of it. I assume they were/are the bearing surfaces. As noted above, the "bushes" are Heim/Rose Joints.
and clean upper joint:
Cost A$219 for the parts (incl. post). Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I’ve just tackled this job. I made light work of it with the Laser 5977 bush tool designed specifically for removing these bushes. The hardest part was getting the old bolts out.
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 705 ![]() ![]() ![]() |
I changed them on ours last week too.
The bolts on mine were seized in good and proper. I had to use a large drift on an axle stand with a sledgehammer to bash it. Once it was finally out it was full of rust. I cleaned it up on a wire wheel but decided in the end to get a brand new one. Not worth the risk because if that fails, the hub comes away for the wishbone and that’s a disaster. |
I was unsuccessful with a large lump hammer on 1 of the the siezed bolts - although the nut came off relatively easily.Hence the saw.
