![]() | Home > Maintenance & Mods (L322) > Replacing Rear Hub Bushes - How To |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1456 ![]() ![]() |
Ok doky. One of the MOT advisories was the rear hub bushes, top and bottom, both sides. I've put it off long enough, but the time came to change them. Over the last wee while, I've been collecting up the parts ... and tools.
Great work fisha
Nice write up! |
Joe,
Good write up. |
I've ordered the new flex pipes that run down the arms ... easier that way and about £18 a side which is fine. Be interesting to see what they are made of when they arrive.
I am not going to try to take the hub off, do it in-situ just as you did. I can see the need for the jack under the lower wishbone to stop the airbag trying to fill. I guess battery disconnection would also help ?
i suppose it would help ... i never bothered. V8 or else ... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35620 ![]() ![]() |
took the liberty to wiki this excellent how to... ... - .- -.
The orientation between the eccentric oval of the bolt head and the 6 bolt faces are the same between the new and old bolts. So when I marked the old bolt head, it allowed me to place the new and old bolts side by side and make sure that I new which face should be facing the mark on the arm. For both sides, the reality was that I chose the longest part of the eccentric oval shape to mark where it met the arm. With that, it wouldn't really of mattered about marking the bolt head as long as I made sure the longest part of the new bolt also met the arm in the same place. Sounds more complicated than it really is. Mark the longest point of the oval in all cases, and match that with the longest point of the new bolt and you'll not go wrong. V8 or else ... |
Having failed to tighten up my rear airbag correctly, I had to have that side apart again.
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 167 ![]() ![]() ![]() |
The brake pipe running transversely across the car at the rear is an absolute doddle if done this way. My 2002 4.4 failed its MOT last year for this. I have access to a ramp. The problem is from below you can hardly see the pipe much less reach it with a spanner. The answer is to raise the suspension to off road height and go in from above. The pipe once you undo the joints is simply pushed into clips on the subframe. Use a proper brake pipe spanner and you'll have the old one off in ten minutes. Now I had to replace a number of the pipes and was not prepared to use steel. I bought copper. I then having cut, bent and fitted the first pipe had to to remove it again to allow another to be replaced. I was surprised to find how work hardened the copper had become. I consider that over time these could with vibration fracture. When I investigated I was shocked to discover the Americans have banned copper brake pipes. I had to hunt to find Kunifer and that's great. So my message is do NOT use copper under any circumstances. If you're used to working with small bore pipe this, from above, is a 30 minute doddle. Couple of other tricks. Remove the master cylinder cap cover the top with a plastic bag and screw the cap back on tight. That stops air getting in and so reduces the brake fluid from pouring out. Btw, Kunifer is roughly the same price as copper. I have a good source if anyone is stuck finding a supplier. Rehab is for quitters!!! RR 2007 3.6 TDV8 Java Black * RR 2007 3.6 TDV8 Zermatt silver * RR 2000 P38 4.6 Met red * Mercedes 300TE 4-Matic * Jaguar 420 (1969) * Nissan 300Z Citroen XM 2.5TD X 6 Bentley Continental R Hydrocon Highlander Hydrocon Hamilton Hydrocon Huntly Am told the ones with a * are to be offered for sale! 😳 Departed LR 1992 110 2.5TD RR 2000 Holland & Holland 4.6 LPG RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue RR 2002 4.4 V8 Zambesi Silver |
DoubleRL322 Member Since: 05 Jul 2016 Location: Orlando, FL Posts: 25 ![]() ![]() ![]() |
Wow, excellent write up!
