Home > Maintenance & Mods (L322) > Service parts |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
Yea thats about it air, oil and fuel filters and make sure the correct oil is used, not cheap bulk stuff.
3rd Jan 2011 2:15pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
I would pay to watch a giraffe do your service......
3rd Jan 2011 3:01pm |
Yes, I don't know the exact figures, but generally 50-60K for an Automatic is a good rule of thumb. Can you not mail order from a Land Rover dealer in the UK or something? Personally though I would just buy off ebay, especially for things like the filters. I imagine the only thing you'll have to source locally would be the oil. |
3rd Jan 2011 3:16pm |
David Member Since: 15 Oct 2010 Location: Murcia Posts: 301 |
cheers guys !! does anyone know the name of that gearbox specerlist in germany ??? zf engineering or something ?????? |
3rd Jan 2011 6:49pm |
You need to fill your signature out - so we all know what year/variant of RR you own so people can recommend accordingly. |
3rd Jan 2011 6:55pm |
On your Profile link at the top of the page in case you ask ... |
3rd Jan 2011 7:00pm |
i put it in here !!!!!! its a 2007 tdv8 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1 Vogue se.. dan is it an easy job to do the box ??????? |
TDV8 with new 6-speed box at 50K should not need a gearbox service yet |
3rd Jan 2011 7:03pm |
Click on the Link at the top of the page where it says Profile between Calendar and Donate scroll down the page and fill in your car details |
myvatn Member Since: 20 Oct 2010 Location: Munich Posts: 80 |
Herr Sagert 0049-2301-9122940
3rd Jan 2011 7:10pm |
is it done ?
3rd Jan 2011 7:13pm |
working now !!!!!
3rd Jan 2011 7:16pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
Yep, see the little FFRR icon below your name on the posts, hover over it with your mouse.. sorted. 2010 Disco XS TDV6, 2009 Freelander 2 GS
3rd Jan 2011 7:18pm |
Why would you say that? The ZF box never needs servicing according to BMW/Land Rover. Then it turns out it needs servicing every 60K. The GM box never needs servicing either, oh and then it turns out it needs servicing at 50K and now has a bad reputation for being un-reliable when it turns out the poor thing just wants clean fluid. Gearbox oil has to work very hard, high temperatures can drastically reduce its effective life. Couple that with the fact it has to absorb the friction material from day 1 - unlike the engine oil that gets changed after the "run in" period. Gearbox tech may have changed (marginally) but oil is still oil. From ZF: “ZF 5 and 6-speed as well as the ZF 4HP20 automatic transmissions are filled maintenance-free with specially developed partially synthetic ATF oils. Maintenance-free fills are intended for normal operating conditions. Especially driving at very high operating temperatures can result in accelerated aging or increased wear of ATF oils. It is recommended, in the event of severe operating conditions, such as : - frequent highway driving in top speed range, - offensive, sporty driving style, - frequent trailer operation, being above average, oil purification (oil change) on automatic transmissions is recommended between 50,000 Miles and 75,000 Miles, or 8 years, depending on the load.” Considering the gearbox is a BMW car gearbox it is already on its limits. I cannot find specific mention to the ZF 6HP26 servicing requirements, only the 5HP24 which ZF specifically say is 60K - and the 6HP is a slighltly longer 5HP. Last edited by dan_uk_1984 on 3rd Jan 2011 7:57pm. Edited 1 time in total |
3rd Jan 2011 7:24pm |
