Home > Maintenance & Mods (L322) > Service parts
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Ok can i just ask, is it a hard job or not ? How is it done ?
Do i need to do oil AND filter or just OIL
What Oil ?????
What box do i have ?
If it is a ZF is that as in ZF engineerig ?
i do kind of agree that oil needs to be changed as like dan says OIL looses its efficieny over time.
If anyone feels like jumping on a flight and doing it for me !!!! Crack on !!!!!! 2007 TDV8 Vogue SE
Post #44386 3rd Jan 2011 7:48pm
dan_uk_1984
What Oil ?????
David, you have the ZF 6HP26. You will need the filter and the oil. Personally I dont do this myself, I take it to a specialist. It is a common BMW box.
Post #44388 3rd Jan 2011 7:54pm
myvatn
Germany 2003 Range Rover Vogue 4.4 V8 Zermatt Silver
@David,
maybe you overlooked my previous post:
Herr Sagert 0049-2301-9122940
or
Herr Jäger 0049-2301-9122945
ZF in Dortmund
2009 somebody payed 375 Euro (incl. tax) for the gearbox oil change incl. diff oil change
the ZF advise is
oil change 40.000km
oil filter 80.000km
cheers Alex
There is a second ZF service in Munich
Post #44389 3rd Jan 2011 7:57pm
dan_uk_1984 wrote:
Gazellio wrote:
TDV8 with new 6-speed box at 50K should not need a gearbox service yet Confused
Why would you say that?
The ZF box never needs servicing according to BMW/Land Rover. Then it turns out it needs servicing every 60K. The GM box never needs servicing either, oh and then it turns out it needs servicing at 50K and now has a bad reputation for being un-reliable when it turns out the poor thing just wants clean fluid.
Gearbox oil has to work very hard, high temperatures can drastically reduce its effective life. Couple that with the fact it has to absorb the friction material from day 1 - unlike the engine oil that gets changed after the "run in" period. Gearbox tech may have changed (marginally) but oil is still oil.
From ZF:
“ZF 5 and 6-speed as well as the ZF 4HP20 automatic transmissions are filled maintenance-free with specially developed partially synthetic ATF oils. Maintenance-free fills are intended for normal operating conditions.
Especially driving at very high operating temperatures can result in accelerated aging or increased wear of ATF oils. It is recommended, in the event of severe operating conditions, such as :
- frequent highway driving in top speed range,
- offensive, sporty driving style,
- frequent trailer operation,
being above average, oil purification (oil change) on automatic transmissions is recommended between 50,000 Miles and 75,000 Miles, or 8 years, depending on the load.”
Considering the gearbox is a BMW car gearbox it is already on its limits. I cannot find specific mention to the ZF 6HP26 servicing requirements, only the 5HP24 which ZF specifically say is 60K - and the 6HP is a slighltly longer 5HP.
ZF seem to be saying 60k if the car has been driven hard or at regular high speed or has been used for towing or similar.
If this TDV8 has had normal use is 31/2 years old and has covered just 50k miles I certainly do not think it needs attention just yet. Maybe, just maybe in 25k.....
Post #44392 3rd Jan 2011 8:06pm
David
myvatn wrote:
@David,
or
ZF in Dortmund
the ZF advise is
oil change 40.000km
oil filter 80.000km
cheers Alex
Thats the one, ive been looking for there service cent in spain as that is where i live. But its bloody 5 hours away !!!! 2007 TDV8 Vogue SE
Post #44397 3rd Jan 2011 8:22pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Is it worth paying to change the gearbox filter & oil... Question
From what i have read it will go when it wants to regardless. 2004 black Vogue TD6
Post #44403 3rd Jan 2011 8:35pm
myvatn
ZF Spain
Post #44409 3rd Jan 2011 8:46pm
dan_uk_1984
Of the times where it "went when it wanted to" how many of those had been serviced within manufacturers guidelines?
Post #44411 3rd Jan 2011 8:53pm
letsavit2
Another job that need's doing then, coming upto 80k, i think ill pay someone else for this one though. 2004 black Vogue TD6
Post #44414 3rd Jan 2011 9:32pm
dan_uk_1984
I paid circa £150 for mine to be done, the fluid alone would have cost me nearly £100...
Post #44416 3rd Jan 2011 9:36pm
I agree its worth doing in the right circumstances especially pre 2006 facelift jag cars, I'm just not ready to believe the ultra reliable 2007 TDV8 needs gearbox attention after a normal full service history 50k miles..... Neutral
Post #44427 3rd Jan 2011 11:03pm
letsavit2
did you spec the oil or just let the specialist get on with it ? 2004 black Vogue TD6
Post #44438 4th Jan 2011 12:52am
