![]() | Home > Maintenance & Mods (L322) > Anyone got the roller blind/ dog guard fitted? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
The parts individually are not big beer, about £20. I keep telling myself it WILL be worth it |
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 ![]() ![]() ![]() |
Sold my spare load net by the way |
Easy this one. Fold your rear seats forward all the way till they click in. On the (now) uppoermost edge of the seat base there are 2 plastic finishers. Yours will either have slots in, or not. If they have slots in, you marry this up with the connectors on the base of the roller blind, then use the forward set of headlining clips in the same fashion. Simples! ![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
I will have a look at that later |
Hopefully will pick up the parts on Thursday or Friday so will be able to fit it all, take some pics and illustrate the point. (And tot up the costs... |
Blimey, they don't make things easy do they?
Back to the dealer today to pick up the correct part. They got 2 of them in to make sure.
Did you get all your parts sorted?
Fitting it isn't the issue, its a piece of cake, getting the parts in a box with the correct part number seems to be impossible for Land Rover though.
Dunsfold Land Rover have them in stock at £5.36 each side if you are talking about part 13286A?
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
i hope you get it sorted |
Those part numbers are not the same ones on the boxes I've had sadly.
No, those on the pic are the Microcat numbers, it then gives ref to the part numbers somewhere else, so which bit is it you actually need? 13286A or 45026A Dan ![]() |
Dan,
