Home > Maintenance & Mods (L322) > Tow Bar |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
I had a detachable towbar fitted to my SC for £550 including VAT and with Westfalia electrics. Haven;lt used it yet but seems pretty good! Got to take a few bikes over to Czech at the end of August.
27th Jun 2014 1:58pm |
Muttley Member Since: 21 Apr 2013 Location: Heathrow Posts: 536 |
Thanks for all the advice guys
27th Jun 2014 6:50pm |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
The post 2005 cars have a setting in the CCF for towing. However, without it set, the car still detects that the trailer electrics are connected and lights up the towing light on the dash accordingly. It is therefore not clear why there is a CCF entry that can also be changed - it seems redundant. I'm currently waiting for a beta version of firmware for the IID Tool which gives access to it so I can experiment with it on and off. Apparently they used to offer it but they took it out because they thought it didn't do anything. The anorak in me wants it enabled because I use it for towing; it must be there for some purpose! One thing I know is that the highway height mode kicks in at 100mph on post 2005 cars; maybe it disables that. I don't think there's any evidence of the engine and gearbox mapping changing - these are sensitive to load anyway (roughly derived from where the throttle is in relation to engine speed). Will report back if I find anything of interest after changing the CCF. |
27th Jun 2014 10:07pm |
ScubaChamp Member Since: 22 Jul 2016 Location: Aberdeen Posts: 11 |
Hi all,
9th Aug 2016 10:16am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1375 |
Just on your PS, removing the receiver involves removing one bolt (24mm from memory). It has a spring clip through it to be removed with pliers. The bolt is at quite high torque to stop the stem of the receiver from moving about when the trailer goes over bumps, so I found I needed quite a big bar on the socket plus a ring spanner on the other end of the bolt to stop it turning. Not every socket will grip as there is a reasonable amount of bolt beyond the nut. I found it desirable to copper grease the nut and the stem of the receiver to stop them seizing in place.
9th Aug 2016 12:08pm |
CS, thanks for your reply.
11th Nov 2016 10:39pm |
Ollie_247 Member Since: 26 Nov 2015 Location: Buckinghamshire Posts: 35 |
you are not far from me I fitted it my self if you need any advise or want to have a look they are super easy to fit took me 2- 3 hours tops.
16th Nov 2016 9:57am |
In the end, I fitted my towbar myself last month (sorry, I didn't take any photos )
20th Jun 2017 5:10pm |
I had the same issue with the towbar clunking in the receiver going over bumps. It's just a case of tightening the bolt more so the sides of the receiver grip the bar. A long bar on the socket helps to achieve the necessary tightening. Only Range Rovers since 1988 |
21st Jun 2017 12:33pm |
hmm. It's a pin and R-clip (not a bolt) that holds the bar into the receiver. I maybe forgot to mention it's a Westfalia, not a Witter tow bar.
21st Jun 2017 1:44pm |
OK, I've seen a Youtube video of the kit you have "Westfalia towbar on range rover 322" or similar and it says that the movement is just a 'feature' of that towbar. I have the LR accessory version which is held in by a bolt which takes a 24mm socket I think and there is also an R clip through it as a secondary security measure. I had assumed yours would be like that, sorry for the confusion. I wonder whether the LR accessory bolt would work on your towbar, and I suppose that is what your expert advice will tell you... Only Range Rovers since 1988 |
21st Jun 2017 2:07pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8515 |
folks on here have used shims to stop the knocking, it needs some free play to make it removable, if it was an interference fit it would not come out easily......
21st Jun 2017 3:13pm |
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 |
Sorry for tagging into this, but a question about the coding.
21st Jun 2017 5:00pm |
