Home > Maintenance & Mods (L322) > Tow Bar
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
If you can undo a bolt, you can fit a tow bar. It is simple. The time taken to fit, is mostly taken up with removing and refitting the rear bumper, but even that is quite simple. Make sure you buy a dedicated wiring kit, piece of cake to fit.
I fitted my own a few weeks ago. Took 3 hours, start to finish and everything worked first time. Thumbs Up
Post #267570 27th Jun 2014 5:51am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I had a detachable towbar fitted to my SC for £550 including VAT and with Westfalia electrics. Haven;lt used it yet but seems pretty good! Got to take a few bikes over to Czech at the end of August.
Did look very easy to fit though to be honest.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #267634 27th Jun 2014 1:58pm
Muttley
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Thanks for all the advice guys Thumbs Up
Much appreciated Thumbs Up
Cheers
Dave Current : 4.2 S/C, now Sold Sad
Previous : V70 Volvo, S40 Volvo ( a very reliable old banger ), E39 M5, Carlton Diplomat and the list goes on Smile
Life Sucks but ya just have to do the best you can with what you have !
Post #267701 27th Jun 2014 6:50pm
ric355
Full Fat Ray wrote:
I think it is only the later (post 2010) vehicles which need coding. Mines a 2006, and when I recently fitted a towbar and 13 pin kit for towing our tin tent, without having to have anything coded the car knows when the tin tent is on the back, and the engine and gearbox mapping is altered (clever ba Censored rds, these chinese!!)
Thumbs Up Thumbs Up
The post 2005 cars have a setting in the CCF for towing. However, without it set, the car still detects that the trailer electrics are connected and lights up the towing light on the dash accordingly. It is therefore not clear why there is a CCF entry that can also be changed - it seems redundant. I'm currently waiting for a beta version of firmware for the IID Tool which gives access to it so I can experiment with it on and off. Apparently they used to offer it but they took it out because they thought it didn't do anything. The anorak in me wants it enabled because I use it for towing; it must be there for some purpose!
One thing I know is that the highway height mode kicks in at 100mph on post 2005 cars; maybe it disables that. I don't think there's any evidence of the engine and gearbox mapping changing - these are sensitive to load anyway (roughly derived from where the throttle is in relation to engine speed).
Will report back if I find anything of interest after changing the CCF.
Post #267735 27th Jun 2014 10:07pm
ScubaChamp
Scotland 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Westfalia Towbar Coding DIY?
Hi all,
Trying to find out whether I can install the Westfalia detachable (or multi-position / farmers) tow bar to my 2011 FF, and crucially, whether or not the coding (which I believe should be done to keep things kosher) is a DIY job, or one for a specialist installer?
Will be looking to buy all the kit (incl. 13-pin dedicated wiring) from PF Jones in the next week or so, but was hoping to avoid additional expense and just fit it myself.
Appreciate any replies.
Scub
P.S. Is it easy enough to remove the receiver on the detachable for greater ground clearance when taking the car off road?
Post #399728 9th Aug 2016 10:16am
CS
Just on your PS, removing the receiver involves removing one bolt (24mm from memory). It has a spring clip through it to be removed with pliers. The bolt is at quite high torque to stop the stem of the receiver from moving about when the trailer goes over bumps, so I found I needed quite a big bar on the socket plus a ring spanner on the other end of the bolt to stop it turning. Not every socket will grip as there is a reasonable amount of bolt beyond the nut. I found it desirable to copper grease the nut and the stem of the receiver to stop them seizing in place.
I have never found it worth removing the receiver for off road driving, the difference in departure angle must be minimal, it's not like say the P38 where the towbar stuck out quite a way and would catch the ground regularly. I do think it worth removing the hook though, (a) as it will make more difference to departure angle and (b) because it needs to be kept clean and lubricated or it seizes up. If you do get earth etc into the receiver then clean it out thoroughly as it will prevent the hook seating properly and safely. I was surprised how little dirt in the receiver was required to cause a problem. Only Range Rovers since 1988
Post #399746 9th Aug 2016 12:08pm
ScubaChamp
CS, thanks for your reply.
Update on the coding: I scored a winner when, on a previous visit to local the dealer, I traded the Manager's offer of a full valet for the promise to code the tow bar for me after I install it! Smile
Typical though, I've still not got around to ordering it. Rolling Eyes
Post #413152 11th Nov 2016 10:39pm
Ollie_247
United Kingdom 2007 Range Rover Vogue SE TDV8 Orkney Grey
you are not far from me I fitted it my self if you need any advise or want to have a look they are super easy to fit took me 2- 3 hours tops.
I got the Witter (farm one) since detachable are in my book a pain in the arse (ive had one on my 530D and never detached it), I also either tow my car trailer or a horse box and don't like the detachable I see it as a week link.
I got electric from PJ jones since RR wanted £400 for them Rolling with laughter and it was plug and play no problems with there kit. The MOT Track days Test Dummy
2007 Vogue SE TDV8
Post #413882 16th Nov 2016 9:57am
ScubaChamp
In the end, I fitted my towbar myself last month (sorry, I didn't take any photos Embarassed )
I bought all the bits from PF Jones and opted for the the cheaper, flange-style (farmers) kit because of two reasons:
1. The more expensive detachable swan neck type was on back order with Westfalia, with delivery time unknown.
2. I tow very infrequently, so the farmers hitch lives most of the time in its dedicated storage bag in the boot, and the armature looks much more discrete without the bulging swan-neck receiver poking out.
The wiring was easy (plug & play), and I'll get the coding done at the next service interval.
Note that, for post 2009 models, the instructions that come with the kit make you think the job is more simple than it is! When you take the rear bumper off, you also need to remove the rear crash bar before removing the factory towing eye brackets ...which is a pig of a job due to limited access in the under-floor compartments on either side! Rolling Eyes
However, having a good socket set helps no end. Smile
The only thing that I think will take some getting used to is the amount of play in the tow bar flange/receiver. It's more sloppy than I had expected (in spite of advice), and it causes quite a knocking noise whenever the trailer goes over a bump. If anyone has a solution or recommendation to reduce the effect of this, then I'll be keen to hear about it! Thumbs Up
Regards,
Post #442130 20th Jun 2017 5:10pm
CS
I had the same issue with the towbar clunking in the receiver going over bumps. It's just a case of tightening the bolt more so the sides of the receiver grip the bar. A long bar on the socket helps to achieve the necessary tightening. Only Range Rovers since 1988
Post #442195 21st Jun 2017 12:33pm
ScubaChamp
Neutral hmm. It's a pin and R-clip (not a bolt) that holds the bar into the receiver. I maybe forgot to mention it's a Westfalia, not a Witter tow bar.
The manual says not to substitute the pin for a 'regular' bolt (or words to that effect), and this I assume is because the pin is shear tested and rated for the application. So I wouldn't be keen to go against that guidance.
However, it's got me thinking about perhaps using some thin shims of metal to reduce the free play ...i think the normal panacea of liberal application of gaffer tape would not prove effective on this occasion and only make it hard/impossible to slide the bar in and out again ...so that one's out.
I'm pretty sure the bar and pin must be sufficiently rated to these occasional shock loads which arise due to the (limited amount of) free play, but I don't think it can be too healthy having the knocks transmitted through the mountings!?
I think I'll get on the phone to PF Jones for some expert advice. Bow down
Cheers
Post #442205 21st Jun 2017 1:44pm
CS
OK, I've seen a Youtube video of the kit you have "Westfalia towbar on range rover 322" or similar and it says that the movement is just a 'feature' of that towbar. I have the LR accessory version which is held in by a bolt which takes a 24mm socket I think and there is also an R clip through it as a secondary security measure. I had assumed yours would be like that, sorry for the confusion. I wonder whether the LR accessory bolt would work on your towbar, and I suppose that is what your expert advice will tell you... Only Range Rovers since 1988
Post #442207 21st Jun 2017 2:07pm
folks on here have used shims to stop the knocking, it needs some free play to make it removable, if it was an interference fit it would not come out easily......
have a search on here I'm sure there are a few threads on it. There is nothing that can't be fixed with a hammer😜😜
Post #442210 21st Jun 2017 3:13pm
Stormin
2003 Range Rover HSE Td6 Epsom Green
Sorry for tagging into this, but a question about the coding.
Recently had an issue where the caravan fell off the tow bar, only damaged caused was the 13pin socket.
As van need that day, I purchased a new socket and rewired, different coloured wires on land rover loom, all works apart from the reversing lights on the van.
Checked van with mates car all works.
rechecked all the connections still no reversing lights
Yet I get a voltage from the pin.
Have priced up a new dedicated loom with Dan, but before I part with £112. Just wanted your advice please
XXXXXXXXXXXXXX
Update it was the fuse , didn't realise the reversing lights had a fuse for the trailer, every day is a school day Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #442226 21st Jun 2017 5:00pm
