Home > Maintenance & Mods (L322) > centre cubby rattle mod
i didnt like the way all the loose bits in the top drawer of the centre cubby slid and rattled about when you opened the double latch to get into the lower portion , so i fettled some pipe insulation and stuck it to the underside of the lid with double sided tape...
its a bit of a bodge job until i figure out something a bit better, but it does work.
Post #441582 15th Jun 2017 1:06pm
ebajema
Great idea Stan, well done !!! What are you thinking about for the upgrade you metioned ?? Low density foam, similar to the stuff they use in camera cases ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #441585 15th Jun 2017 1:19pm
probably something like that eugene, darker/black in colour and fitted better.. ... - .- -.
Post #441587 15th Jun 2017 1:22pm
Weegie
Good job, Stan but don't put your specs glass down. They end up scratched if you do. Wink Whistle John
GAP iiD BT
Post #441590 15th Jun 2017 1:34pm
specs are pound shop jobbys so not to worried John Thumbs Up ... - .- -.
Post #441595 15th Jun 2017 1:46pm
Baltic Blue
I like that idea.
I had stopped using the top tray just because of the same rattle problem.
Cheers Stan. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #441600 15th Jun 2017 3:01pm
thanks mike...
i found that when you opened it to get to the bottom section the stuff in the top would slide back out of the trays..this mod solves that Wink ... - .- -.
Post #441605 15th Jun 2017 3:26pm
Forgot the top of the cubby opened....... Rolling Eyes
Good job I didn't put anything in there, could have gone missing There is nothing that can't be fixed with a hammer😜😜
Post #441619 15th Jun 2017 6:13pm
Freddie The Fish
United Kingdom 2011 Range Rover SE 4.4 V8 Fuji White
Anyone ever figured out what goes in the spaces, presume one side is for a mini maglite as it fits perfectly but what about other side, it looks designed for something ?
Post #441622 15th Jun 2017 6:59pm
maybe 'ones' fountain pen...... ... - .- -.
Post #441627 15th Jun 2017 7:10pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Correct Stan, except its a roller ball pen, courtesy of Jaguar in mine....
Post #441635 15th Jun 2017 7:49pm
Too many pen holders, is there not one in the top dash cubby/glovebox too... There is nothing that can't be fixed with a hammer😜😜
Post #441639 15th Jun 2017 8:12pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Good idea stan. Thumbs Up
Post #441654 16th Jun 2017 5:21am
thanks greg.... Thumbs Up ... - .- -.
Post #441658 16th Jun 2017 6:43am
no pics yet but replaced the fairly hard pipe insulation stuff with some spongy foam ripped from a kitchen scouring pad ..the foam is white unfortunately but is softer and wont damage things like sunglasses etc.. ... - .- -.
Post #442082 20th Jun 2017 11:45am
