Home > Technical (L322) > Has she been tuned?
nebc100
Luxembourg 2003 Range Rover SE Td6 Monte Carlo Blue
Has she been tuned?
Hello All,
Just a small question...
I bought my FF a few weeks ago, and sadly the gearbox is now failing. It is being replaced next week, but I was just wondering two things...
1. The replacement GB will be SONNAX fitted. Replacement TCC also, so hopefully should be OK afterwards. What mileage do most people get from a reconditioned GB with the SONNAX valve casing?
2. I don't want to put extra strain on the GB, so is there any way that I can check if the engine has been tuned/chipped?
Thanks for your comments.
Nick
Post #441472 14th Jun 2017 7:55am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Afaik, the only way is a rolling road, other than one of those add on tuning boxes, no one can tell.
Post #441480 14th Jun 2017 9:56am
nebc100
OK... thanks.
It isn't like with the TD5 Discovery that I have where I can download/upload a tuning file with my Nanocom?
I have bought the IID Tool. Can this upload a tuning file? If so, could I not simply upload a "standard" tuning file to be sure that I put it back to standard?
Post #441482 14th Jun 2017 10:00am
Weegie
It isn't possible to check with the iiD tool. I asked Patrick at Gap and he confirmed it wasn't. John
GAP iiD BT
Post #441483 14th Jun 2017 10:04am
nebc100
OK.. thanks!!
Post #441484 14th Jun 2017 10:05am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I would have thought if it had been tuned, then if you got LR to put the latest software on the car then that would wipe out any remap that could have been put on the ECU.
An expense, but you would know it would then be standard but doubt they could tell you if it had been remapped either.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #441490 14th Jun 2017 10:57am
mjdronfield
I don't believe the gearbox fails cos of a remap. The valve body is soft, so it wears. The sonnax kit lines the bore of a main shaft so it doesn't wear... others can obviously explain that better... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #441523 14th Jun 2017 4:34pm
gregdav
If it is remapped, I think you will be disappointed with the performance if you go back to standard.
Post #441533 14th Jun 2017 5:28pm
nebc100
The gearbox won't fail BECAUSE of the remap, but a remap will certainly put more strain on the gearbox, and will cause it to wear faster.
Sadly, my gearbox is starting to fail, and I am having it replaced next week, and consequently I want to try and make sure that it lasts as long as possible.
Post #441556 15th Jun 2017 7:28am
nebc100
I doubt that I would be disappointed!! My normal car is a Discovery 2 TD5 MANUAL!! Any Range Rover will seem fast compared to that!!
Post #441557 15th Jun 2017 7:29am
