Home > Technical (L322) > Has she been tuned? |
nebc100 Member Since: 14 May 2017 Location: Altlinster Posts: 76 |
Hello All,
14th Jun 2017 7:55am |
OK... thanks.
14th Jun 2017 10:00am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
It isn't possible to check with the iiD tool. I asked Patrick at Gap and he confirmed it wasn't. John
14th Jun 2017 10:04am |
OK.. thanks!! |
14th Jun 2017 10:05am |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
I would have thought if it had been tuned, then if you got LR to put the latest software on the car then that would wipe out any remap that could have been put on the ECU.
14th Jun 2017 10:57am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7829 |
I don't believe the gearbox fails cos of a remap. The valve body is soft, so it wears. The sonnax kit lines the bore of a main shaft so it doesn't wear... others can obviously explain that better... 2011 Range Rover Vogue SE 4.4 TDV8
14th Jun 2017 4:34pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
If it is remapped, I think you will be disappointed with the performance if you go back to standard. |
14th Jun 2017 5:28pm |
The gearbox won't fail BECAUSE of the remap, but a remap will certainly put more strain on the gearbox, and will cause it to wear faster. Sadly, my gearbox is starting to fail, and I am having it replaced next week, and consequently I want to try and make sure that it lasts as long as possible. |
15th Jun 2017 7:28am |
I doubt that I would be disappointed!! My normal car is a Discovery 2 TD5 MANUAL!! Any Range Rover will seem fast compared to that!! |
15th Jun 2017 7:29am |
