Home > Technical (L322) > How to switch off the "Adaptive" part of Cruise |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
try this, while cruise is on, hold the reduce distance button to the lowest level and keep pressed, it will turn off the adaptive part of the cruise control. ... - .- -.
12th Jun 2017 11:29am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
Thanks Stan!
12th Jun 2017 12:28pm |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
Good info Stan.
12th Jun 2017 1:49pm |
i hope this method does work..
12th Jun 2017 2:16pm |
Thanks Stan. On a cruise ship right now so don't think I can try it on the bridge. Will try when I get back at the end of the week. 2012 5.0L S/C
12th Jun 2017 2:22pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 583 |
Great info thanks Stan. Will be trying it tomorrow and will report back. If not ... I'll be back in touch Graeme! Mike - MPx
12th Jun 2017 2:59pm |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 |
Absolutely love my ACC - one of the reasons I got the AB. When I need to overtake on motorway I just accelerate as normal, set new ACC speed. If I do find myself slowing down by someone going slower, I just enjoy following on and then overtake later when I can. Really love the ACC, wouldn't want to be without it. 2005 L322 Vogue Gold gone
12th Jun 2017 10:32pm |
jumpin mouse Member Since: 28 Feb 2016 Location: North West Posts: 222 |
I'm totally with RosytanH on this one. I could not imagine owning an RR without adaptive cruise. Best feature on the car but you do need to add a bit of pedal sometimes to make up the slack in the system. |
13th Jun 2017 11:13am |
It doesn't work on my vehicle. However I did get to read the manual to discover that forward alert has to be enabled in the service menu for forward alert to be active, which I want in case it helps avoid clashes with the skippies in my area. Spotted a big one just off the other side of the road tonight whilst doing 100 kph, heading further off rather than out in front. |
13th Jun 2017 11:40am |
Sadly doesn't work with my one either. If I keep the "- distance" tab pulled once its on just one < then after about 5 seconds the picture of the car goes off on the dash....but it hasn't switched off the radar. Its just as adaptive as ever.
13th Jun 2017 5:39pm |
that's a bummer, i'm sure i read that procedure worked... ... - .- -.
13th Jun 2017 5:59pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
I asked a dealer in the context of a 2016 405 whether one could select 'ordinary' CC and was told yes, by double clicking the selector switch. I don't know if that is right or if yes, if it works in the 322 also, but it might be worth a try. Only Range Rovers since 1988 |
13th Jun 2017 7:38pm |
To disable ACC in the CCF with an IIDtool you will need to have full CCF access using the latest beta version s/w, achieved by requesting full access from Gap Diagnostics. The parameters to be changed are: Speed control – adaptive fitted Standard speed control display type – Adaptive speed control full display plus priority messages Speed control – ACC Adaptive speed control indication in instrument cluster – enabled The fuse for the radar unit in the engine bay fuse panel has to be removed to stop it sending unexpected data. My 4.4 only has 1 radar unit whereas it appears that the 5.0 has a 2nd so might have a 2nd fuse. The 5.0 has a distinct ACC ecu located in the right rear panel whereas the 4.4's ACC is handled by the ecm so a 5.0's rear panel fuse may also need to be removed or the ACC ecu unplugged. |
13th Jun 2017 8:59pm |
Ooooerr Graeme that sounds properly scary to get right! But many thanks for the info. Some Qs:
13th Jun 2017 11:30pm |
