Home > Technical (L322) > TDV8 4.4 oil consumption |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7827 |
I don't need to put any in mine between services. Check your coolant in case your oil cooler is cracked and the oil is now in the coolant....common issue.....
11th Jun 2017 2:51pm |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 145 |
Will do!! 2012 TDV8 Vogue SE 4.4 |
11th Jun 2017 6:36pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Frans, may wanna look this thread:
12th Jun 2017 8:38am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1387 |
Mine has never needed to be topped up between services (about 50,000 miles now). The electronic level display shows whole divisions and may therefore exaggerate the drop compared with a dipstick and I have found it very sensitive to whether the car is level, and also the temperature of the oil, slight variations can make quite a big difference to what is shown on screen. Only Range Rovers since 1988 |
12th Jun 2017 11:10am |
I want my oil level to be in the middle or one notch up, when engine is cold , so when the engine is at operating temperature oil level is going to be at the full or one notch below. when checking oil level of hot engine wait for 15-20 sec. for sensor to stabilise. |
12th Jun 2017 11:53am |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
Unnecessary quote removed
14th Jun 2017 9:54am |
My das 28-32 mpg and your A380 ?
14th Jun 2017 12:23pm |
nino_nino
14th Jun 2017 2:59pm |
