Home > Technical (L322) > TDV8 4.4 oil consumption
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
I am new to the 4.4 TDV8.Had the car since May 2017.Have done 6500kms of which 4600 is on a recent trip towing the offroad van.Car sits on 96500kms.Oil consumption went from just below full to half full.Is this normal?My D3 used NO oil.
The car has LR MP till end July.There is oil on a pipe coming out of the passenger side turbo.Think it is the boost pipe.Is this normal?The car doesn't smoke under acceleration.
Thanks 2012 TDV8 Vogue SE 4.4
Post #441214 11th Jun 2017 11:06am
mjdronfield
I don't need to put any in mine between services. Check your coolant in case your oil cooler is cracked and the oil is now in the coolant....common issue.....
The oil cooler is really a heat exchanger with the coolant. Just a thought....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #441239 11th Jun 2017 2:51pm
Frans@Yamorna
Thumbs Up Thumbs Up Will do!! 2012 TDV8 Vogue SE 4.4
Post #441258 11th Jun 2017 6:36pm
nino_nino
Frans, may wanna look this thread:
http://www.fullfatrr.com/forum/topic35977.html
Post #441301 12th Jun 2017 8:38am
CS
Mine has never needed to be topped up between services (about 50,000 miles now). The electronic level display shows whole divisions and may therefore exaggerate the drop compared with a dipstick and I have found it very sensitive to whether the car is level, and also the temperature of the oil, slight variations can make quite a big difference to what is shown on screen. Only Range Rovers since 1988
Post #441316 12th Jun 2017 11:10am
nino_nino
I want my oil level to be in the middle or one notch up, when engine is cold , so when the engine is at operating temperature oil level is going to be at the full or one notch below. when checking oil level of hot engine wait for 15-20 sec. for sensor to stabilise.
Post #441321 12th Jun 2017 11:53am
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Unnecessary quote removed
nino_nino
You have this spot on Fella - a lot of folk fill their engine to nearly the max when doing a oil renew.
This is a big mistake as oil will expand when it gets hot and this will cause stress on components and engine failure.
A380 power units are primed at 60% capacity - and are throttled back to 80% at max thrust with 75,000 HP per power plant on tap:
out of interest:
The engine's suck in over 1.25 tons of air every second.
The fan operates at nearly 3,000 rpm each with tip speeds at 1.5 times the speed of sound.
Now what does your Rangie do ???
Nice post nino_nino
Post #441478 14th Jun 2017 9:54am
nino_nino
My das 28-32 mpg and your A380 ? Very Happy
ps
what kind of aceleracion do you get on the take off??
Post #441501 14th Jun 2017 12:23pm
EmiratesA380
nino_nino
acceleration is very similar to the Rangie on full throttle - just pant your foot down on the motorway and dont take the gas off
Give you some idea whats its like sat in the pilots seat:
Emirates have the best pilots in the World both male & female
MPG on the A380 - bit like a Rangie, - if you ever look at whats MPG shes doing its time to by a shrimp
Good luck my friend
Post #441513 14th Jun 2017 2:59pm
