Home > Maintenance & Mods (L322) > High Beam Mod
Page 1 of 4 1234>
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
High Beam Mod
Got these bad boys delivered and going to replace the halogen ones to match the Xenons. Can't wait.
Next project is the replace the side fins to color coded ones.. Zermatt Silver[/img]
Post #439135 21st May 2017 12:07pm
Danwilderspin
How did it turn out?
Post #441115 9th Jun 2017 9:19pm
scotcruz
Looks gr8.. will post a pic when I'm out..
there is no delay unlike halogen bulbs and gives a flash effect.. It's looks cool Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #441116 9th Jun 2017 9:30pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Where did you get them?? 2014 vogue se
Post #441133 10th Jun 2017 10:32am
scotcruz
Got them from fleBay mate..
http://www.ebay.co.uk/itm/371786510808 Current:
Past:
Post #441137 10th Jun 2017 11:12am
chefkenmore
Thank you Thumbs Up Thumbs Up 2014 vogue se
Post #441146 10th Jun 2017 1:07pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Interested in what they perform like Wink Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #441159 10th Jun 2017 6:13pm
How can they be 80W per lamp when the quoted running current is a maximum of 670mA. More like 8W per lamp.
80W per lamp and they would need a method of disipating the heat.
Post #441167 10th Jun 2017 7:17pm
TOF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Are there any error lights on the dash from fitting these...
Post #441170 10th Jun 2017 7:50pm
80W per lamp and they would need a method of dissipating the heat.
My thoughts exactly , everything I have tried runs with a cooling fan because of the heat generated and that is before I believe the fantasy outputs quoted, I'm now trying some with a great big bunch of braided tails to dissipate the heat to keep the noise down of four or six cooled lamps running. 2008 MY Supercharged
Post #441183 11th Jun 2017 1:27am
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Most of these aftermarket bulb are not E stamped, they can look good and they can be more effective then normal bulbs however if you have an accident this is a quick way of blaming you for the accident or voiding the insurance for non compliant parts being fitted
Post #441198 11th Jun 2017 8:53am
Clive603
England 2004 Range Rover HSE Td6 Orkney Grey
Lumens are the unit for visible light output, watts for input power. Typically approaching 5 times as many lumens per watt from LED as from halogen so a LED drawing 8 watts from 12 V should be roughly equivalent to a 40 Watt halogen.
Bit more complicated in practice because what you actually see and how many lumens you measure depend on how the native monochromatic LED light is turned into "white". Visual effect differs too. See warm white, cool white and daylight white for domestic LED bulbs. Considerably more light, as in brighter, for your watt from daylight white than from warm white. May also get more light into the useful beam pattern with LED rather than Halogen making things look even brighter.
Clive
PS took a closer look at the advert. Looks like its 640 mA (nominal) draw at 24 Volts input for 1500 lumens which is about right for 80 watts equivalent. LED should run on constant current so how they get the 12 V and 24 V capability in with proper 24 V current draw I don't know.
Post #441222 11th Jun 2017 12:35pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
i have thought about these myself few times, anyone know if they are error free on pre 2005 range rovers. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #441248 11th Jun 2017 4:04pm
Lukie
Don't worry about sorting the bulbs out for error free, just turn of bulb check in LCM I'm sure if a high beam bulb is out you would notice it
Post #441279 11th Jun 2017 9:42pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
80W per light would also be illegal for road use in UK
Post #441309 12th Jun 2017 10:15am
Page 1 of 4 1234>
