Home > Technical (L322) > What's this part ?
Freddie The Fish
United Kingdom 2011 Range Rover SE 4.4 V8 Fuji White
What's this part ?
Can anyone identify the part in the middle of this picture just under the engine cover, it has a hard plastic shell and a few pipes coming out of it, fuel filter can be used for orientation. Its quite a clicky little thing but has random bouts of loud clicking which is why I ask, is it on its way out ?
Post #440722 5th Jun 2017 3:02pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Is it the oil pump? or is that too high?
Does it tick irregularly on cold start then quieten down? Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #440729 5th Jun 2017 4:52pm
Baltic Blue
Is it No.2
Vacuum/ scavenge pump ?
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #440731 5th Jun 2017 5:07pm
not the scavenge pump that is on the other bank.
it is the HP fuel pump providing the HP diesel feed to the injectors. It is a fuel on demand system, which is why its not a constant tick.
ticking is probably normal...... There is nothing that can't be fixed with a hammer😜😜
Post #440732 5th Jun 2017 5:21pm
Freddie The Fish
Hard to tell from the diagram what bit goes where ? Here's another without the cover on
Post #440733 5th Jun 2017 5:22pm
still the HP pump. the black plastic part is a cover, if you look round the back you can see the pump and 2 diesel lines with grey sleeving on them coming out.
It runs off a sprocket drive into the timing gear in the head, there is a solenoid on the top which is probably what you can hear clicking. There is nothing that can't be fixed with a hammer😜😜
Post #440734 5th Jun 2017 5:23pm
Freddie The Fish
Thanks, mind a little more at rest now as never heard it before (but can't say I've ever really listened). Had an oil change and air filters done a day ago so was wondering if linked.
So for a bonus point what's the high pitched whistle that goes on for a minutes after the engine is turned off ?
Post #440735 5th Jun 2017 5:34pm
what whistle? the one inside the cabin?
in which case its the fan on the temperature sensor next to the up/down/face controls on the AC panel. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #441085 9th Jun 2017 5:18pm
Freddie The Fish
Comes from middle of engine somewhere, under the cover
Post #441086 9th Jun 2017 5:21pm
