Home > Technical (L322) > Key won't turn in ignition fix 2002-2005
Page 3 of 5 <12345>
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Will give 13 incl. shipping to Germany with normal int. royal mail, you have PayPal? Best rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #440705 5th Jun 2017 1:14pm
PM sent Pete
Post #440709 5th Jun 2017 1:34pm
mr_spock
Pete, did I send you the link to the US magnet supplier? I can't find it in my email but would be happy to post here if I can remember your email address to search for!
Post #440723 5th Jun 2017 3:32pm
I'd forgotten where I got the info...!!! I'll PM you my email address feel free to post the link... Pete
Post #440738 5th Jun 2017 6:22pm
mr_spock
Thanks Pete, found the message. This was the info I'd found:
Follow the instructions in this PDF to dismantle the ECU casing to get at the solenoid:
http://www.blackbox-solutions.com/photos/L322lock.pdf
Then read this thread on the magnet fix.. the part numbers etc are spread between posts so there's a bit to read. Some have tried lubricating the solenoid with little or only temporary success.
http://www.rangerovers.net/forum/6-range-r...urn-6.html
Magnet is here:
https://www.kjmagnetics.com/proddetail.asp?prod=R422
Post #440794 6th Jun 2017 12:23pm
themule
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
Thanks very much for the link dingg - have you tried that method? Mine is 2007, it seems odd if the column lock has changed from earlier models it still suffers from the exact same problem. I have never experienced it or heard of it on any other car.
Post #440926 7th Jun 2017 9:01pm
dingg1
hi
no I haven't tried the jumper switch idea , mine has been sorted with drilling the casing and lubing with silicone lubricant , if it fails completely I will try the method of fitting a push button switch into those pinouts in the link I last posted , as it appears to be the easiest fix.
Post #440929 7th Jun 2017 9:31pm
themule
This method of disconnecting the module does work and is easy. I tried with 2 needles and shorted the 2 pins together and I could start the car fine. Im not sure what to do next - can I leave these 2 wires shorted permanently, will that drain the battery or do I need a switch. Im certainly not driving around with 2 sewing needles stuck a few inches above my knee Very Happy I need something more permanent.
It was also frustrated when I removed the steering column shroud - it's very well built behind there and screwed together very solidly better than other vehicles I have seen - all the more frustrating that it's suffering from these issues.
Post #441026 8th Jun 2017 9:08pm
dingg1
I would wire in a rocker switch permanently to those pin positions and locate the switch under the column shroud so its invisible to everyone - glad to hear it works could save a lot of faffing about and expense
Post #441043 9th Jun 2017 7:01am
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
My steering lock failed open.Right now for starting car i have to first remove fuse 18.
Jumpering pins 1-7 (connector c2055) seems quite easy job and ok upto here
however what i cannot understand the following suggestion:
"If you want to keep the "normal" behaviour, a timer relay wired to the interior lights would be your best bet."
As i am totally ignorant would please someone explain to me how this can be done.
Many thanks
Post #441572 15th Jun 2017 11:19am
Meerbusch
@Haylands, the solenoids had arrived, many thanks. Normal I would buy them also in US, but they want 20$ shipping.....
the only corect way to solve this common problem is to build out the column, and remanufacture the Solenoid and the White-housed Motor. Also remanufacure the electronic platine.
Best regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #441681 16th Jun 2017 11:42am
AKIS
By reading better thread i saw that pinning of 1 and 7 of c2055 can have an effect only to non bmw models. Big Cry
Googling around have found in a us land rover forum owners with steering column problems to mention "www.advancedkeys.com" which seems to be quite interesting solution as escape from need to buy a replacement steering column and face similar problems in future.
Its a keyless entry kit and the ak-105s which i am looking for gives you the ability let key,with a nice and easy conversion, ALL THE TIME IN IGNITION SWITCH,which solves turning key problems.
Supplier confirms that kit is fully compatible with RR,at least mine which is model 2004 and is straight forward installation.In cost terms is much cheaper than to buy a used steering column.
My steering lock has stucked in open position.
Wondering whether with defective steering lock as mine if there is any possibility while driving status of steering lock to change and lock???or locking during driving cannot be done.
Any comments and how such an installation sounds to site experts will be much appreciated????????
Post #441688 16th Jun 2017 1:03pm
Yep, jumping pins only works with the later models...
The keyless start kits leave the RFID in the key next to the ignition all the time... starting will work (although I don't see how they bypass the immobiliser??) BUT, if you leave the RFID next to the pickup around the ignition key you can't lock the door as it thinks you have left a key inside the car....
They say it is compatible with the FF but that is different from "working as it should" when it doesn't work they will just say it's your fault... they keep your money... check out these things very thoroughly first and ask for references....
Also without all the factory fit anti theft stuff your insurance company won't be too happy....!! Pete
Post #441936 18th Jun 2017 8:18pm
AKIS
Haylands thanks for your reply.Decided to buy second hand steering column for fitting and will try to open ecu of damaged one to see if can repair it.
Just for being on safe side after replace the steering column will any reprogramming be needed or will be plug and play?
Many thanks
Post #442187 21st Jun 2017 11:22am
AFAIK it's all plug and play, no ECU's in it, just motors, solenoids and a few other unreliable items...... Rolling Eyes
Good luck.... Thumbs Up Pete
Post #442189 21st Jun 2017 11:43am
Page 3 of 5 <12345>
