Home > Maintenance & Mods (L322) > Mass Air Flow Sensor Brand Advice |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
My experience is with a mates xtrial, they seem to eat mass airflow meters , he got a genuine at Ferrari money and it lasted 6 months , then an eBay one which lasted 6 weeks , a second eBay one has now lasted 8 months at a cost of a 10th of the Nissan one. Reading that back i havent really helped 2015 4.4 AB
3rd Jun 2017 5:41pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3130 |
I fitted a Bosch over 2 years ago and no probs. Make sure there isn't a hole/leak anywhere else in the ducting/piping as this could cause the prob too. |
3rd Jun 2017 5:58pm |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 |
Thanks all. I have decided to just replace the MAF sensor with a new Denso one.
4th Jun 2017 7:10am |
OK, Have replaced the MAF sensor with a new Denso one and this has cured the 'lumpy' idle issue - I cleared the 'too Lean' 0171 code and it hasn't returned (Yet!). The old sensor was covered in dirt on one side.
4th Jun 2017 11:37am |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 500 |
what's the mahoosive black box on the left-hand side (RHD Driver's side) as you look under the bonnet?
4th Jun 2017 6:21pm |
Ah. Right. Thank Strider. I too shall leave well alone. |
4th Jun 2017 6:55pm |
Just to complete this saga - I found that when the new battery was fitted, the washer pipe (which is supposed to be clipped to somewhere by the battery negative terminal with a metal clip) had become unclipped and was getting partially pinched off when the bonnet was closed.
5th Jun 2017 2:34pm |
I had a similar issue with my 4.2 years ago. Changing the MAF and Lambda sensors didn't do anything! Then I updated the motor management ECU and all problems went away! MY 2010 5.0 SC Galway green and sand interior!!
6th Jun 2017 12:33am |
