Home > In Car Electronics (L322) > I just killed my rear heater blower |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 |
You turn the ignition on by pressing the start button without your foot on the brake.
29th May 2017 11:56am |
That may have been the power button you referred to....sorry.... 2011 Range Rover Vogue SE 4.4 TDV8
29th May 2017 12:00pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Yes that is the one I mean by 'bottom left'... It won't light up now.
29th May 2017 12:05pm |
I hit the main START STOP button. But it is not an absolute shut down, yes it should stop the frontcigar lighters running - but it doesn't actually. Radio still works too when you turn the car 'OFF'. Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
29th May 2017 12:10pm |
The radio and the power sockets will all stay live till the car shuts down a few minutes after.... when the instrument cluster goes off. Learnt that after I spent £200 on a cooler box that won't stay powered up, even though manual says it should.... 2011 Range Rover Vogue SE 4.4 TDV8
29th May 2017 12:46pm |
Doesn't the rear socket stay on perm? Cheers, Greg
29th May 2017 1:30pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1448 |
You can also get a permanent live from the rear fuse box. 2021 D350 Fifty Edition - Carpathian Grey
29th May 2017 1:34pm |
None of the sockets are permanent. You have to mod it if you want that, as Stan says.
29th May 2017 2:00pm |
So aside of sockets and ignition, back to my dead rear blower....
30th May 2017 6:15am |
UPDATE - IT'S FIXED!!!!
30th May 2017 10:42am |
