![]() | Home > In Car Electronics (L322) > I just killed my rear heater blower |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7879 ![]() ![]() ![]() |
You turn the ignition on by pressing the start button without your foot on the brake.
That may have been the power button you referred to....sorry.... 2011 Range Rover Vogue SE 4.4 TDV8
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Yes that is the one I mean by 'bottom left'... It won't light up now.
I hit the main START STOP button. But it is not an absolute shut down, yes it should stop the frontcigar lighters running - but it doesn't actually. Radio still works too when you turn the car 'OFF'. Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
The radio and the power sockets will all stay live till the car shuts down a few minutes after.... when the instrument cluster goes off. Learnt that after I spent £200 on a cooler box that won't stay powered up, even though manual says it should.... |
Doesn't the rear socket stay on perm? Cheers, Greg
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1456 ![]() ![]() |
You can also get a permanent live from the rear fuse box. 2021 D350 Fifty Edition - Carpathian Grey
None of the sockets are permanent. You have to mod it if you want that, as Stan says.
So aside of sockets and ignition, back to my dead rear blower....
UPDATE - IT'S FIXED!!!!
