![]() | Home > Technical (L322) > Gearbox and or transfer box problem |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
The shift interlock solenoid should be de-energised by the application of the foot brake i.e. the transmission ECU cuts the current when it receives a signal from the brake switch. The transmission knows that it’s in ‘P’ or ‘N’ via the inhibitor switch. Is ‘P’ being displayed on the instrument panel?
Phils Member Since: 01 Aug 2016 Location: North west Posts: 71 ![]() ![]() ![]() |
Too late to look now, to be honest i was kind of assuming it was the trf box causing issues.
Transfer box ECUs typically appear on eBay for £20-£25 so it’s not an expensive thing to test by substitution if you suspect that yours is faulty. I generally think of the ECU as being the least likely cause of any issue, though I suppose they must fail occasionally?
It is a strange one, it knows what position it is in, but makes no effort to move it. I checked power to ecu and that was good, relays looked good to.
Well i fixed it, i stripped the motor operated the thing manually loads if times using a power probe and it works now. |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
Sorry first for my english... i try my best |
Sounds more like the torque converter is breaking up. Well mostly....... |
