![]() | Home > Technical (L322) > Climate controls overactive |
nebc100 Member Since: 14 May 2017 Location: Altlinster Posts: 76 ![]() ![]() ![]() |
Hello all,
Thanks... I will give that a try.
Keith A Member Since: 25 Oct 2012 Location: Sherborne, Dorset Posts: 105 ![]() ![]() ![]() |
Fitting guide here
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Mine has a new fan and new FSR. It does exactly the same. |
Before I order a new part, just a quick question.
I would think the FSR is OK. Have you cleaned the vent in front of the cabin sensor? |
I haven't a clue when it was last cleaned. I have only just bought the car!!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
Get a can of compressed air and blow it into the little grille next to the controls for the up, down, face direction. There is a temperature sensor in there for cabin temp and a little fan which sucks air over it, if it's all dusted up then it will send the wrong signals and you get cold air.
Thanks for that. The problem that I have is not that we are getting HOT air, but FREEZING cold air and the fans are al.ost permanently running at almost full speed.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
I don't know what year or model yours is, but the earlier l322's have a little thumb wheel by the centre vents, it's easy to miss it when you don't know it's there. You can adjust it hot and cold by the indicators red blue either side.
^ they have that on all MY sir |
Ok... A bit more info...
thats what it should do.
To clean the air inlet for the temp sensor I used a cocktail stick to clear the fluff out. Or just stick a vacuum cleaner nozzle on the front. Or have the console sides off, and take off the panel to clean it if you're determined!
