Home > Technical (L322) > Central locking not working
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
I dont know if this is connected to my interior light post, but after a problem with the battery discharging yesterday I cant get the central locking to work on either the remote or manually. I have tried the battery re-set and the turn ignition on/off press unlock then lock three times whilst holing the unlock button on the remote (has worked before) but there is no response from the central locking and the red led on the remote flashes 10 times - is this a code? Could this be connected to the interior light problem? QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #438055 11th May 2017 7:31pm
Deltaevo
United Kingdom 2002 Range Rover HSE 4.4 V8 Alveston Red
My CL wouldn't work either I had my key fob renewed but couldn't get the central locking to work, I also noticed my cigar lighter didn't work, checked the fuse in the rear panel and changed it, checked the fuse for the central locking it had blown. Fuse changed everything worked once I had done the key reset. Just a thought.
Nick
Post #438062 11th May 2017 8:12pm
Spelunker
Thought about the fuses for this and the interior light problem - the thing is the handbook lists the fuse as also controlling the windows and they are working. I will have a look tomorrow and keep my fingers crossed.... QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #438084 11th May 2017 9:22pm
Dolphinboy
Bcu controls this function and may need replacing - it's under the passenger seat.
Post #438089 11th May 2017 10:32pm
Deltaevo
Unnecessary quote removed
Hi
My windows worked without the fuse, I hope it's just the fuse rather than the BCU. Let us know how you get on.
Nick
Post #438235 13th May 2017 8:07am
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
she mabe in transport mode central locking not working interior lights not working if you had to jump start you could have spiked the ecu you will need a reset which can only be done with correct software . had same prob with mine after jump start tried everything but it was a simple fix . hope its the same for you
Post #438239 13th May 2017 8:47am
Spelunker
Checked all the relevant fuses today and all are ok. The central locking/alarm set works with the key but not with the remotes even after the correct re-sync procedure. None of the courtesy lights are working, that is the rear tailgate/rear passenger(can be turned on manually)/front passenger(cant be turned on at all)/puddle/door mirror & glovebox lights. The map lights do work and the glovebox light worked for a while after I removed/replaced one of the central locking fuses accompanied by a whirring noise from the centre console, but then it went off. Would a vehicle electrician be likely to have the correct software or am I likely to need to go to a JLR main dealer? QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #438277 13th May 2017 6:17pm
alistairh
Are your front wipers working? Sounds like it's partially in transportation mode. Failed or failing bcu?
Post #438280 13th May 2017 7:30pm
Spelunker
As far as I can tell, everything apart from the courtesy lights and the central locking works. QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #438292 13th May 2017 10:11pm
rik
definitely transport mode you will need a reset don't pull fuses and waste your time this happened to me and I was standing on my head trying to resolve easy fix
Post #438331 14th May 2017 10:06am
rik
you will need main dealer or someone with correct diagnostic tool normal software will not reset this as I had auto electrician working on mine for over an hour . went to auto tec Greenock and 5mins later she was back up and running £50 out of the wallet give them a call and they will advise what software required mechanic using laptop told me his software cost £70.000
Post #438333 14th May 2017 10:12am
Spelunker
Job done. Went to a local sparkie with the correct software and he sorted it in five mins. £45 well spent (by which I mean it gets SWMBO off my back). QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #439071 20th May 2017 8:46pm
Deltaevo
Glad you got it sorted Smile
Post #439086 20th May 2017 10:17pm
