Home > Technical (L322) > Where is the LCM-Light Control hiden on L322 2003 TD6 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35373 |
14th Apr 2017 7:51am |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
thanks, I was wanting to check the connections on the ECU as I am getting related fault codes for suspension. and ECU, so thought I might have aC An bus coonetion fault, researching says the various ECUs are interconnected.
14th Apr 2017 11:46am |
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 |
Hey lounge_on_wheels
20th May 2017 6:18pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
I would recommend disconnecting the battery to disconnect the LCM, for the avoidance of any gremlins creeping in, and also creating a safe state (for you, the LCM and everything connected to it!
20th May 2017 10:16pm |
Thanks Joe90
20th May 2017 11:38pm |
Can't go flat - BONUS! However, ensure your physical key can lock and unlock the drivers door beforehand (leave another door or the boot open when testing) - alarm may go off until you put key in ignition.
20th May 2017 11:56pm |
If i leave it sat for a week will i have pair up keys or any of that craic afterwards?
21st May 2017 9:49am |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Absolutely no need to disconnect the battery. Had mine in and out a few times over the years. |
22nd May 2017 9:51am |
Unnecessary quote removed
22nd May 2017 1:04pm |
