Home > Technical (L322) > Where is the LCM-Light Control hiden on L322 2003 TD6
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Can some one advise where I might find the LCM-Light Control please on 2003 L322 TD6 Thanks
Post #434873 14th Apr 2017 7:34am
all info in the WM Wink ... - .- -.
Post #434874 14th Apr 2017 7:51am
lounge_on_wheels
thanks, I was wanting to check the connections on the ECU as I am getting related fault codes for suspension. and ECU, so thought I might have aC An bus coonetion fault, researching says the various ECUs are interconnected.
LCM-Light Control v11
• 0xC ECU EEPROM fault
• 0x57 Air suspension active/inactive
• 0x8E Right side marker defective
• 0x8F Left side marker defective
• 0x0094 Unknown
• 0x0095 Unknown
Post #434884 14th Apr 2017 11:46am
Cooper1275
Ireland 2006 Range Rover Vogue SE Td6 Buckingham Blue
Hey lounge_on_wheels
Did you have a go at pulling this out?
Also if you did pull this out did you disconnect the battery first or is it ok to pull it out and re connect when needed?
Thanks
Post #439061 20th May 2017 6:18pm
I would recommend disconnecting the battery to disconnect the LCM, for the avoidance of any gremlins creeping in, and also creating a safe state (for you, the LCM and everything connected to it!
Mine was all nice and dry, but didn't hurt to clean up the connectors and pins with a squirt of this and that to help it on its way Thumbs Up .
Post #439085 20th May 2017 10:16pm
Cooper1275
Thanks Joe90
My only issue is that the drivers side sidelight does not turn off.
the light is permanently disconnected and everything else works fine.
i was going to remove the lcm and send it away to get fixed.
no issues with leaving the battery disconnected for a week though? Confused
Post #439094 20th May 2017 11:38pm
Can't go flat - BONUS! However, ensure your physical key can lock and unlock the drivers door beforehand (leave another door or the boot open when testing) - alarm may go off until you put key in ignition.
I have had mine sat out on the drive for three weeks disconnected (big rear suspension job!), no worries. .
Post #439096 20th May 2017 11:56pm
Cooper1275
If i leave it sat for a week will i have pair up keys or any of that craic afterwards?
If it is just "reconnect and fire her up" then great Thumbs Up
Post #439120 21st May 2017 9:49am
steptoe
Thanks
Absolutely no need to disconnect the battery. Had mine in and out a few times over the years.
Post #439232 22nd May 2017 9:51am
lounge_on_wheels
Unnecessary quote removed
Hi, no never pulled it put.
Post #439256 22nd May 2017 1:04pm
