Home > Technical (L322) > Coding a new key
NVB
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
Coding a new key
I've received my new key from Land Rover. It physically locks and unlocks the door but the buttons do not operate the locks remotely. I guess it needs coding. Can I do this myself, or do I now need to take the car to a dealer?
This is a second key, so I do have one fully operational key if that makes a difference.
Cheers
Nvb RR History
1988 2.4td Classic 1999 to 2020
1992 3.9efi Westminster Classic 2004-2005
2005MY L322 3.0TD6 Vogue 2016 to current
Post #438983 20th May 2017 9:22am
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
I would imagine knowing what model it was would give the more knowledgeable a chance of answering this question. If you fill in your profile model will be shown on the left of your posts.
Post #438988 20th May 2017 9:36am
Follow the handbook procedure? .
Post #438989 20th May 2017 9:42am
Weegie
To synch the keys
1) Get in and close all doors. Turn ignition on and off quickly and remove the key (all within about 5 seconds).
2) Within 30 seconds of turning the ignition off, while holding down the "unlock" button, press the "lock" button three times. Release the "unlock" button. (You may or may not get the confirmation from the door locks.) Holding the key at your head level provides best results as the key sensor is in the side window pillar.
3) Repeat for each key you want to initialize within 30 seconds after the last one you initialized (if you have more).
4) Right after doing the last key, quickly put the key back in the ignition and turn it on/off again to finalize.
Between stages 2 and 3 above DO NOT put the additional key in the ignition (stage 1) as this starts the whole process again.
You will need to do it for all keys.
As Rod says put your vehicle in your avatar box. From your previous posts it is a 2005 Vogue but not whether it is Td6 or 4.4. John
GAP iiD BT
Post #438990 20th May 2017 9:46am
NVB
Sorry, my vehicle is in my profile and also my signature, but guess I should have made it clearer. It's a 2004 05MY L322 TD6
Thanks RR History
Post #439006 20th May 2017 11:26am
NVB
Do you know, I didn't think to check that. Didn't imagine it would be covered in there. I'll have a look now.
Cheers RR History
Post #439007 20th May 2017 11:28am
NVB
Weegie wrote:
To synch the keys
Thanks for that. It's a td6 so does that confirm the above procedure is correct? Assuming I dont find it in my owners manual.
Cheers RR History
Post #439008 20th May 2017 11:34am
rodp
That's the procedure for my 2003 TD6, so assume same for yours.
With regard to the list of vehicles, some folk list motors past and present so may not be current. If you click on the little picture under a users name the current vehicle spec pops up, very useful Thumbs Up Not getting at you, just trying to be helpful.
Post #439011 20th May 2017 12:14pm
Weegie
Covers the Td6 Thumbs Up John
GAP iiD BT
Post #439016 20th May 2017 12:38pm
NVB
No problem, no offence taken. Perhaps I have to click something somewhere to make it show. The details are in my profile, but I don't seem to have the clicky link under my profile picture. Any clues as to what I need to do?
Cheers RR History
Post #439018 20th May 2017 1:06pm
NVB
Thanks RR History
Post #439019 20th May 2017 1:08pm
rodp
Cheers
Sorry but no, it just appeared when I joined
Post #439027 20th May 2017 1:38pm
rodp
Ah, just looked, in your profile there's a section marked "range Rover profile", mines filled in but yours appears to be blank ?
Post #439029 20th May 2017 1:39pm
NVB
It's there when I look. How strange
I have just deleted and re-entered it. Let's see if that works
Edit: yay, success RR History
Post #439051 20th May 2017 6:00pm
rodp
Thumbs Up Thumbs Up Thumbs Up
Post #439053 20th May 2017 6:02pm
