![]() | Home > Technical (L322) > Coding a new key |
NVB Member Since: 14 May 2017 Location: Essex Posts: 103 ![]() ![]() ![]() |
Anyway, back on topic. In case anyone else is reading this. Weegie's process worked. Now have two fully working keys. Just got to work out how to stop the seats adjusting when I unlock with my new key ![]() 1988 2.4td Classic 1999 to 2020 1992 3.9efi Westminster Classic 2004-2005 2005MY L322 3.0TD6 Vogue 2016 to current |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Great post , after purchasing a vogue with two keys and one missing a transponder chip , I bit the bullet and bought a chip and after several attempts of coding and losing the original key operation , got it all back and two keys working thanks. Well not quite , this morning the new coded key unlocked the car ok , but not the ignition, so I must have put back the original in after confirming it , then put in new key which turned the ignition on , but if you do that too quickly after original it will catch the code before coding on vehicle shuts down. So back to the start. I put the original key in to confirm door unlock as it lost it while recoding the new transponder! Can someone answer when confirming button pressing do I wait till the light on the key stops flashing or do it before it stops. |
Can only activate the lock unlock buttons on second key , would this be right, do I have take original to a locksmith along with original key. The second key has ever worked , so after investigating , I found that it had no transponder chip in it . I have followed instructions on this thread but second key doesn't activate ignition , any help appreciated.
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
sadly yes this thread is only for pairing the remote functions
