![]() | Home > Technical (L322) > ZF5HP24 Whine! |
DanPoole Member Since: 01 Mar 2017 Location: Kent Posts: 59 ![]() ![]() ![]() |
Has nobody had any similar symptoms? |
Having had a gearbox specialist look over this, they have said that it's definitely the gear set on its way out and it needs a full rebuild.
MONT322 Member Since: 22 Jan 2017 Location: Surrey Posts: 33 ![]() ![]() ![]() |
Hi mate, did you ever get to the bottom of this? Sounds like I have the same issue on my 04 L322! |
It was the gearbox unfortunately mate. Had to have a full rebuild. |
Not so Happy New Year to me then!! Lol!! Thanks for getting back to me mate
IF you can get the gbox dropped out then get it up to rrphil. He is the top guru for this gearbox and also very competitively priced.
Yes - RRPhil really knows these gearboxes inside out, I've read many of his posts.
It will only cost a coupla hundred quid to get the box out, then pallet it to rrphil. If the box is all that’s wrong with yours, then you will have a great FFRR with no worries for anthe 100,00 + miles. Would be well worth it I reckon. |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
as DB has said , cheaper to have it repaired than lose heaps selling the car with a fubard gear box pal |
