Home > Technical (L322) > ZF5HP24 Whine! |
DanPoole Member Since: 01 Mar 2017 Location: Kent Posts: 59 |
Has nobody had any similar symptoms? |
24th Apr 2017 7:26pm |
24th Apr 2017 8:10pm |
Having had a gearbox specialist look over this, they have said that it's definitely the gear set on its way out and it needs a full rebuild.
20th May 2017 2:13pm |
MONT322 Member Since: 22 Jan 2017 Location: Surrey Posts: 33 |
Hi mate, did you ever get to the bottom of this? Sounds like I have the same issue on my 04 L322! |
1st Jan 2018 10:35am |
It was the gearbox unfortunately mate. Had to have a full rebuild. |
1st Jan 2018 11:20am |
Not so Happy New Year to me then!! Lol!! Thanks for getting back to me mate
1st Jan 2018 2:27pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
IF you can get the gbox dropped out then get it up to rrphil. He is the top guru for this gearbox and also very competitively priced.
1st Jan 2018 6:54pm |
Yes - RRPhil really knows these gearboxes inside out, I've read many of his posts.
1st Jan 2018 8:34pm |
It will only cost a coupla hundred quid to get the box out, then pallet it to rrphil. If the box is all that’s wrong with yours, then you will have a great FFRR with no worries for anthe 100,00 + miles. Would be well worth it I reckon. |
2nd Jan 2018 8:22am |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
as DB has said , cheaper to have it repaired than lose heaps selling the car with a fubard gear box pal |
2nd Jan 2018 1:32pm |
