Home > Technical (L322) > Td6 over fueling |
Muddydisco Member Since: 01 Apr 2017 Location: Tamworth Posts: 20 |
2002 147k miles Having poor mpg 20 at best.
16th May 2017 6:38am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Won't get a chance to play until Friday, but could have a look at my numbers then if that helps? (Tempts fate! ) .
17th May 2017 5:31pm |
If you could that would be good. Going to wiggle wires this weekend and also do vacuum test to make sure I have no leaks. |
18th May 2017 5:20am |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
I am watching this thread as I only achieve 20 mpg , but they are short journeys , {td6}, I thought that was normal. |
18th May 2017 6:09am |
To achieve 20mpg I'm only just tickling the throttle, on 15 mile steady run. It's more the concern of the fueling at tickover have I got 4 injectors overfueling or two under fueling? After reading as much as I can it's looking electrical. But it's finding the bad sensor or wiring that's making the engine think it needs more fuel. |
18th May 2017 6:32am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Checked my live data last night with my IID tool and this is what I am getting:
18th May 2017 8:08am |
Cheers Tigger!!!
18th May 2017 5:02pm |
Glad to be of assistance MD, guess you have moved to a FF from a Discovery...like I did a few years back.
19th May 2017 2:45pm |
Yeah Had a disco since age of 18 i'm now 37! I still have it in fact it's undergoing full rebuild. then a Freelander 1 for a sort time, then TD5 D2, then Audi, now back to LR |
19th May 2017 3:20pm |
Well certainly no Vaccum leaks sitting at 28in/hg, at tickover and not moving either after switching off. Infact I still was holding some vaccum when i broke into the system to fit the gauge from being stood all night.
20th May 2017 12:41pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 294 |
What was outcome mate as I have exact same issue.
24th Jun 2019 2:57pm |
