Home > Technical (L322) > Td6 over fueling
Muddydisco
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Td6 over fueling
2002 147k miles Having poor mpg 20 at best.
Had issues with starting found no 1 and 2 injectors leaking off.
So I've replaced them. But still crap mpg. Bit the bullet and brought IID tool.
So upon looking at faults I've got
p0314-01 cylinder imbalance control general electrical failure.
Looking at live data on a warm engine at tick over, my fuel comp is
Cyl 1 653mm3
Cyl 2 655mm3
Cyl 3 7mm3
Cyl 4 651mm3
Cyl 5 1mm3
Cyl 6 651mm3
And mass air flow of 478 mg/H
From what I've read anything above 2mm3 is over so what the hell is going on?
I have no visible smoke at tick over or under load. The mass airflow seems to be low for milligram per hour I would of expected something like 3 grams per second on this 3ltr???
It's had low pressure pump, and fuel filter replaced. Any pointers which way to head. I have no baseline figures to compare it too.
Many thanks
Nick
Post #438559 16th May 2017 6:38am
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
on Cyl 3 give the injector loom plug a wriggle whilst you have the iidtool on and see if the reading changes, could be the connector?
Post #438680 17th May 2017 9:23am
Won't get a chance to play until Friday, but could have a look at my numbers then if that helps? (Tempts fate! Shocked ) .
Post #438716 17th May 2017 5:31pm
Muddydisco
If you could that would be good. Going to wiggle wires this weekend and also do vacuum test to make sure I have no leaks.
Post #438752 18th May 2017 5:20am
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
I am watching this thread as I only achieve 20 mpg , but they are short journeys , {td6}, I thought that was normal.
Post #438754 18th May 2017 6:09am
Muddydisco
To achieve 20mpg I'm only just tickling the throttle, on 15 mile steady run. It's more the concern of the fueling at tickover have I got 4 injectors overfueling or two under fueling? After reading as much as I can it's looking electrical. But it's finding the bad sensor or wiring that's making the engine think it needs more fuel.
Post #438756 18th May 2017 6:32am
Discotigger
Checked my live data last night with my IID tool and this is what I am getting:
Cyl 1: +2
Cyl 2: -1
Cyl 3: -1
Cyl 4: -1
Cyl 5: -1
Cyl 6: -0
all values are mm3
My TD6 runs smooth and gets 29mpg (I do long runs every day of 50 miles each way to work and back).
I had a reading of +7 on Cyl 1 a couple of years ago and got the Injector replaced, as said any reading above +7 and the injector is most likely faulty.
Your readings seem way too high though, so I'd check the wiring loom first as it could be faulty and giving poor signals. You could also try swapping the injector that is showing the low reading (Cyl 5 at 1mm3) to another cylinder and see if the reading moves with it. If not then it's probably not the injectors at fault.
Your MAF reading seems about right, I was getting similar at tickover.
Post #438764 18th May 2017 8:08am
Muddydisco
Cheers Tigger!!!
At least i know it's not most likely the injectors 1 and 2 where replaced last week. so yes going to look at looms and stuff.
Just had a handbrake clip pop off and cook the rear drivers drum. spring and pin rubbing the disc and disc cover. had to strip that out tonight so more work for weekend when new bits turn up.
I'm a proper fatty owner! Faults appearing faster than I can fix them Smile
Post #438819 18th May 2017 5:02pm
Discotigger
Glad to be of assistance MD, guess you have moved to a FF from a Discovery...like I did a few years back.
Yep, the joys of FF ownership, had a good few jobs to sort on mine so far this year. Rolling Eyes
Still, I wouldn't trade her in for anything else. Thumbs Up
Post #438891 19th May 2017 2:45pm
Muddydisco
Yeah Had a disco since age of 18 i'm now 37! I still have it in fact it's undergoing full rebuild. then a Freelander 1 for a sort time, then TD5 D2, then Audi, now back to LR Smile
Post #438896 19th May 2017 3:20pm
Muddydisco
Well certainly no Vaccum leaks sitting at 28in/hg, at tickover and not moving either after switching off. Infact I still was holding some vaccum when i broke into the system to fit the gauge from being stood all night.
Loom wiggle test not really shown much up, couldn't get figures to change, but in graph mood no5 was fluctuating on it's own. without any wiggles. It looks like an OE part and has a date sticker of 2002 on it so it matches cars age.
Going to change it as a matter of course.
Unplugging Injectors when running, no 1, 2, 4, 5, 6 all had effects on tickover but no3 had no effect on tickover or really whilst revving, thinking possible injector here and engine is compensating using the rest.
Each unplug has pinged the correct ecu fault as no load on injector and correct numbers.
So other than waiting payday to buy a loom and another recon injector, I'm hoping this will cure it.
Post #439017 20th May 2017 12:41pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
What was outcome mate as I have exact same issue.
Cheers
J Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #519534 24th Jun 2019 2:57pm
