Home > Maintenance & Mods (L322) > Brake pads 60% worn or 40% left!
pld118
Just had contact from main dealer to report pads all round are 60% worn and advising to check them again in 6 months.
I will change them soon anyway but is that not why these care have break sensor wires?
Post #438613 16th May 2017 5:19pm
in theory the sensors work ok if both sides wear down the same but them once the sensor gives you the warning you will have to replace it which isn't such a bad thing...
the occasional visual inspection is best.. ... - .- -.
Post #438615 16th May 2017 5:24pm
Buy new pads and ceramic grease and monitor every month or so. The wear sensors will alert you should you forget.
Replacement is easy front and rear. Thumbs Up Si. <This is my name.
Post #438618 16th May 2017 5:57pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
... or do it like my other half and only get the pads replaced when the maximum radio volume can no longer overcome the metal on metal grinding (screaming?) sound... Laughing
Post #438665 17th May 2017 7:51am
mpirie
Assuming both pins come out easily from the front calipers! Big Cry
Mike
Post #438670 17th May 2017 8:53am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Pretty sure that only one side per axle has a pad sensor on it, not both from memory when I replaced my brakes.
Works in theory, but as has been said a visual inspection is best Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #438674 17th May 2017 9:01am
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
correct, only one sensor on front and one on rear.
Post #438682 17th May 2017 9:27am
mzplcg
So, a set of pads which cost over 200 quid, and you're going to waste 40% of that (80 quid) ?
As long as they are wearing evenly, which is easy to check, getting down to 10% has never caused me problems. And that's about the point that the wear sensor turns the light on. Thumbs Up
Post #438684 17th May 2017 9:35am
I used a thin drift to push them out assisted by a small hammer and didn't really have any problems, but a valid point nonetheless. Thumbs Up Si. <This is my name.
Post #438687 17th May 2017 9:49am
Mikey
Only if you opt for genuine
Plenty of cheaper options, be it budget, OEM or uprated
Post #438691 17th May 2017 11:19am
mpirie
Sensors are on the front left (nearside) and rear right (offside)......and they are different sensors.
Unfortunately for me, one of my pins was seized solid and i ended up having to cut the pin in half and using the punch to get both parts out.
Just as a side note, if one pin does get stuck, remove the caliper mounting bolts and you can get the pads out without the stuck pin having to be removed. The new pads can then be slotted in and the second pin used to hold them in while you remount the caliper.
Mike
Post #438694 17th May 2017 12:18pm
mpirie
......if you price up a set of genuine pad fitting kits, you will nearly double to cost of the pads .....make sure you are sitting down when you call JLR !
Mike
Post #438695 17th May 2017 12:20pm
pld118
mzplcg wrote:
So, a set of pads which cost over 200 quid, and you're going to waste 40% of that (80 quid) ? As long as they are wearing evenly, which is easy to check, getting down to 10% has never caused me problems...
Thanks for all replies.
I've fitted pads to the car before so am comfortable with buying and DIY, was just a bit surprised that the 60% worn advice inferred getting new ones.
mzplcg has nailed it for me really Thumbs Up
Incidentally, the existing pads are genuine LR, fitted at a main dealer... and the fronts have always squealed. Using ceramic paste did eradicate it for a couple months but the squeal returned!
Post #438699 17th May 2017 3:21pm
Rangeyman
I for one will get my moneys worth and have never had a problem waiting for the wear indicator but I do like to have a visual check when I can ,you can generally see if you look between the wheels these days on most vehicles anyway.If you read this forum there are many who suggest new discs as well as pads way before they are needed so am not sure why you would not get your pads worth before you change discs anyway.Use some common sence,a dealer or garage only want to fit components as much as possible and will do allsorts to try and sway you to part with cash whenever possible .
Post #438704 17th May 2017 4:07pm
