![]() | Home > Maintenance & Mods (L322) > Brake pads 60% worn or 40% left! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35522 ![]() ![]() |
in theory the sensors work ok if both sides wear down the same but them once the sensor gives you the warning you will have to replace it which isn't such a bad thing...
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Buy new pads and ceramic grease and monitor every month or so. The wear sensors will alert you should you forget.
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
... or do it like my other half and only get the pads replaced when the maximum radio volume can no longer overcome the metal on metal grinding (screaming?) sound... |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
Assuming both pins come out easily from the front calipers! ![]() Mike |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Pretty sure that only one side per axle has a pad sensor on it, not both from memory when I replaced my brakes.
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
correct, only one sensor on front and one on rear. |
So, a set of pads which cost over 200 quid, and you're going to waste 40% of that (80 quid) ?
I used a thin drift to push them out assisted by a small hammer and didn't really have any problems, but a valid point nonetheless. ![]() I eat rat poison. A man ain't truly been insulted until he stands buck naked in front of a woman and she didn't even notice. Or care. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1790 ![]() ![]() |
Only if you opt for genuine Plenty of cheaper options, be it budget, OEM or uprated |
Sensors are on the front left (nearside) and rear right (offside)......and they are different sensors.
......if you price up a set of genuine pad fitting kits, you will nearly double to cost of the pads .....make sure you are sitting down when you call JLR !
Thanks for all replies. I've fitted pads to the car before so am comfortable with buying and DIY, was just a bit surprised that the 60% worn advice inferred getting new ones. mzplcg has nailed it for me really ![]() Incidentally, the existing pads are genuine LR, fitted at a main dealer... and the fronts have always squealed. Using ceramic paste did eradicate it for a couple months but the squeal returned! |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
I for one will get my moneys worth and have never had a problem waiting for the wear indicator but I do like to have a visual check when I can ,you can generally see if you look between the wheels these days on most vehicles anyway.If you read this forum there are many who suggest new discs as well as pads way before they are needed so am not sure why you would not get your pads worth before you change discs anyway.Use some common sence,a dealer or garage only want to fit components as much as possible and will do allsorts to try and sway you to part with cash whenever possible . |
