Home > Technical (L322) > 4.4 tdv8 hesitation at 80 mph'ish
Page 3 of 4 <1234>
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
I have done that too, bought an original sump pan, and then bought the correct oil direct from ZF, remember it being a bit of a pain to get to the right people at ZF but far cheaper to buy the oil that way.
In truth didn't make much difference to the gear change but I figured changing oil was cheaper than changing the gearbox.
The official LR oil change point is at 120/-m I believe. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #397844 26th Jul 2016 9:25pm
your old oil that came out, was it discoloured? ... - .- -.
Post #397850 26th Jul 2016 10:03pm
pld118
stan wrote:
i looked on topix and i beleive its LTB000454v2.
I think you have added a zero that ain't there Stan?
Straight copy and past from Topix, this is the one:
" Title LTB00454v2 - Engine Hesitation/Powertrain Control Module Update (various issues)
Global reference: LTB00454v2
Navigation path: Bulletins Technical Bulletins 303 - Engine System
Publication date: 11-May-2012 08:08:42 "
Post #438252 13th May 2017 11:52am
but i'm old so i'm allowed to make mistakes......
Ner Ner ... - .- -.
Post #438253 13th May 2017 12:09pm
pld118
To be fair, you know more than the Franchised LR garage staff Censored
Laughing
Post #438255 13th May 2017 12:14pm
cadoganpier
United Kingdom 2018 Range Rover Autobiography SDV8 Loire Blue
Is there any way to know if you have this update without going to the main dealer?
Post #450859 13th Sep 2017 7:59pm
Baltic Blue
I have got an invoice from when mine was serviced and it is included in the itemised bill.
It might be worth you checking old invoices if you have any, to see if it it is mentioned.?? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #450880 14th Sep 2017 8:04am
do you get this hesitation?.....if you don't then don't worry... ... - .- -.
Post #450884 14th Sep 2017 8:53am
cadoganpier
Hi, yes I do, especially noticeable when using the cruise control set at around 75mph.
Post #450886 14th Sep 2017 8:57am
Baltic Blue
I was aware of it for a long time and just put up with it "coughing" at about 75/80mph, but since I had it done it feels better all the way through the rev range and definitely no more "coughs".
The danger now is "drifting" through the 70's and before you know it you are cruising along at 80+., so I have set my speed alarm at 80 to "wake me up". G reg 2.5VM Vogue Portofino red 1991- 1999
Post #450888 14th Sep 2017 9:10am
cadoganpier
Just had the update done at Newbury 4x4, much much better, especially when using the cruise control, completely cured the "hunting" I was getting
Post #451584 21st Sep 2017 11:13am
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
How obvious is this hunting?When travelling on CC @ 128kmph(80mph)there is a faint hunt.Not sure if this is only the cc trying to maintain the set speed or the hunting you guys are talking about.Driving without cc at that speed it is smooth.Is this "coughing"very obvious? 2012 TDV8 Vogue SE 4.4
Post #451626 21st Sep 2017 2:45pm
its occasional and yes you will notice it.... ... - .- -.
Post #451629 21st Sep 2017 2:58pm
cadoganpier
Hi Frans, it wasn't horrific just sometimes the car couldn't decide what gear/throttle combo it wanted and would sort of cough and lurch a bit, you noticed it most on the cruise control when going down a hill, the thing just seemed confused, it wasn't dire but once I notice something my ocd kicks in....... it's smoother now at all speeds and the coughing/hunting issue has gone.
Post #451740 22nd Sep 2017 2:51pm
Frans@Yamorna
Thumbs Up Thumbs Up 2012 TDV8 Vogue SE 4.4
Post #451755 22nd Sep 2017 4:40pm
Page 3 of 4 <1234>
