Home > Technical (L322) > Front Headlights Washer Jets - Not Working |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 |
I disconnected the line and blew compressed air through it. From this spray came out the nozzels on the bumper. Therefore all is connected right, therefore the only problem appears to be the pump/ or fuse. |
8th May 2017 12:00pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
Don't forget that the h/l washers only operate every 5th time the w/s washers do and need the h/l to be switched on before they will operate. |
8th May 2017 1:25pm |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
I had faulty jets and the mot failed.
9th May 2017 10:47pm |
Yes, it looks like the pump isn't working for the headlights.
12th May 2017 2:06pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
the rear washer isnt required for the mot... ... - .- -.
12th May 2017 2:10pm |
You'll also need to swap the plugs, easiest way in is to remove the passenger side wheel arch |
12th May 2017 10:29pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Unnecessary quote removed
12th May 2017 11:25pm |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
I believe the OP has changed to a newer model TDV8 but hasn't gotten around to updating his profile yet. |
14th May 2017 12:43pm |
