Home > Technical (L322) > Rear wheel speed sensor circuit open
Chasazim
Australia 2004 Range Rover Vogue 4.4 V8 Epsom Green
My iid tool tells me i have the rear right wheel speed sensor is open circuit, what is that and what needs to be fixed,please advise.
Is this another of the electrickery things or is it important.
Post #436865 3rd May 2017 6:49am
ABS speed sensor either broken, or reluctor ring rusted away and not doing its job anymore .
Post #436939 3rd May 2017 5:38pm
Chasazim
Hello again, still no joy with my suspension problem. I lifted the back and removed the wheel arch lining to see better, removed the sensor easily, unpluged it gave it all a clean, nothing noticable, looked like new.lol then while under the car i noticed the left tire looked a bit worn on the inner edge, on a closer look i could see wire Rolling Eyes both rear tyres had the inner edge worn right through, an imminant blowout. Put the spare on the worst worn side and connected the Iid tool. All faults cleared and suspension working fine, up down up down. Very Happy booked the car in for two new tyres and a wheel alignment. Went to pick up the car and, you guessed it BONG, llights all on. Connect the Iid tool rear right wheel speed sensor open circuit, this time the Iid tool wont clear the fault so i am stuck in ride height.any ideas gratefuly accepted. Big Cry
Post #437811 10th May 2017 6:47am
Keith A
United Kingdom 2009 Range Rover Vogue SE TDV8 Buckingham Blue
I have this problem at the moment.
Hopefully fitting a new wheel speed sensor will rectify it. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Mini Cooper Race Car Smile
Post #437850 10th May 2017 11:29am
Chasazim
Let us know how it goes, my sensor looked like new, and a new sensor her in the nanny country is big dollars Big Cry
Post #437853 10th May 2017 12:11pm
Keith A
So did mine!
How quickly do you want a sensor? I bought the wrong one initially, which I believe should work with pre 07 cars.
Could send it to you for postage cost.
Keith Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #437854 10th May 2017 12:37pm
Chasazim
PM me with the cost , not urgent but you know how painful it is to have something that doesn,t work, thanks for the offer, are all thesensors the same except for the length of the connector?
Post #437860 10th May 2017 1:20pm
Keith A
No idea.
Just know that pre 07MY the part number for the rear sensor is SSF000021 and 07MY upto 10MY is SSF500021. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #437862 10th May 2017 1:29pm
Chasazim
Yes that seems to be the correct sensor, Very Happy please pm me how much to buy and send to Perth West Australia.appreciate you response.
Post #437864 10th May 2017 1:45pm
Keith A
Postage is £9.55 according to Royal Mail. They think it's also 5-7 working days delivery, which I'll take with a pinch of salt.
The sensor cost £20, but I'm not asking anything for it.
Keith Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #437870 10th May 2017 2:30pm
Chasazim
Wow thanks for that, how can i get the funds to you, or can you send receiver pays. Don,t want to cause you too much hassel.
Post #437871 10th May 2017 2:43pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Keith A wrote:
No idea.
yes putting the wrong later model sensor in the rear left wheel added 100kph on my speedo speed when I was only doing $60kph! LOL
Post #437980 11th May 2017 10:53am
Chasazim
The plot thickens, today while driving at about 50kph i applyed brakes and got a loud grating sound from the front and BONG the suspension inactive and ABS lights were on, braked again , no noise, parked for a while and then when driving home same again, grinding noise when i apply brakes and dash lights up but brakes work as normal drives normal except for suspension inactive and ABS lights. Very unsettling at the least. Any ideas? I will check with my Iir tool to see what faults if any. Thanks ahead of time.
Post #438658 17th May 2017 5:33am
GraemeS
Why do you not suspect pads worn through?
Post #438660 17th May 2017 6:21am
Chasazim
The grinding noise is only momentary when the dash lights come on there is no noise and brakes work as normal but no suspension alteration. If was worn brakes wouldn,t it grind all the time?
Post #438661 17th May 2017 7:09am
