Mine did that for the first time ever on saturday and it wasn't fun even without a caravan.
i think / hope mine was caused by a front caliper sticking on as when i got home i checked the temp of the front calipers and the drivers was 35 deg and the passenger side was 140 deg !
I rebuilt it with new seals but haven't had chance to test it yet.
The hardest bit about the PCV is the valve bolts I think but i did mine when I did the valley pan so changed it on the bench.
I replaced the gearbox cooler, the gearbox stat at the same time and pipes when we rebuilt the transmission. i think my rad is ok as it flushed through and the drain plug works ok. I lalso have done the 80 degree mod but the aux heater pump isn't working which is also on the list...
i do get an occasional transmission temp sensor sporadic fault logged from time to time so it may even be that playing up.
