Home > Technical (L322) > Light whine at 80mph |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2256 |
Gents as stated above on a 2007 4.2 I am getting a light whine at 80mph whilst under load it disappears at 70 and over 85
13th Jan 2017 9:05pm |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
Is the wife in the car? |
13th Jan 2017 11:12pm |
Not when it is a light whine but certainly when it is loud through the range |
13th Jan 2017 11:21pm |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
Unnecessary quote removed
10th May 2017 4:31pm |
Nope it is still the same and another 8000 miles in so who knows?No faults found and drives absolutely perfect |
10th May 2017 8:37pm |
Interesting thanks for the info will have a look thinking of putting on a four post ramp and running up to see if I can hear anything |
4th Jun 2017 9:33am |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
Just swap to a Barolo and slow down a little so you don't spill any. You'll be fine. 2017 5.0 Autobiography Supercharged
4th Jun 2017 3:01pm |
If it goes when you lift off - it could be the rear diff. An oil change of the rear diff should be done every 80K |
4th Jun 2017 3:20pm |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 94 |
Service bulletin LTB00498NAS1 regarding the transfercase whine attached, yes its for later models, but still maybe worth a look...
7th Jun 2017 1:56pm |
Mightymarcos Member Since: 24 May 2015 Location: Alvechurch, near Birmingham Posts: 31 |
Mine was the same although around 70-75 was peak whine. I changed the transfer box oil for new factory oil and it got no worse over nearly 40k miles. Taking a rest from Land Rovers for a bit....... |
9th Jun 2017 5:00pm |
