Home > Technical (L322) > Towbar newbie question - Westfalia 323051
Page 3 of 3 <123
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
miggit wrote:
rik wrote:
have you got air suspension? I am not sure what happens when you are driving or whether ride height is adjusted before it locks off but mine tows superb with swan neck ride height is never an issue
That is a function of the trailer electrics, when the ECU detects a load on the trailer wiring it locks the ride height and changes the gear selection pattern, it is nothing to do with what towbar is fitted Thumbs Up
I never got to the bottom of this! I have had fitted at the stealers 13pin electrics! Doesn't lock the ride height, doesn't stop the fog lamps coming on the car, doesn't change the gear selection!
Only stops the sensors bleeping! 2014 vogue se
Post #437884 10th May 2017 4:25pm
Weegie
Did they activate in the CCF when they installed the electrics, David?
May not apply: https://www.gap-diagnostic.com/faq-items/t...-settings/ John
GAP iiD BT-Sold
Post #437899 10th May 2017 6:22pm
chefkenmore
They did John!
But they couldn't get it to do it! They had the car twice then eventually sent it out with the tow bar settings switched off! Bought my gap tool and switched it back on again! 2014 vogue se
Post #437921 10th May 2017 9:03pm
Page 3 of 3 <123
