![]() | Home > Maintenance & Mods (L322) > Maintaining - looking for advice on maintaining L322 plastic |
wood78987 Member Since: 03 Mar 2016 Location: South Wales Posts: 135 ![]() ![]() ![]() |
Just done mine this weekend with autoglym tyre gel and the other plastic bits on the car. Looks much better now |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Anything you use on it will wear off qickly and it will be dull grey again in no time! Gtechniq do a product which is expensive but supposed to be a long term solution to dulled plastics which you may want to look up on google. |
Caddyshack Member Since: 03 May 2017 Location: Guildford Posts: 61 ![]() ![]() ![]() |
Yes, g technic is the product you need, I think it is c4, you only need a tiny bottle....it is like nothing else I have used before, forget plastic polishes, the g tech properly revives it. |
The main reason that the plastics go grey is because they continue curing with UV light so the oils come to the surface and get washed off. The g-technic stuff works well and I have found that it is much more permanent if you heat the plastic up before applying it - CAREFULLY !!
buffalo4 Member Since: 01 May 2016 Location: Doncaster Posts: 143 ![]() ![]() |
Will the heat not deform the panel ? |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
I tried a host of treatments and then saw a chap on another forum using a matt black plastic paint. I have done the same and it looks good. Is this where I put the car details and a bit about myself ?........ |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
do mine every couple of washes with Autoglym - Bumper & Trim Gel
Any brand Nick ? |
Bought the Gtechniq stuff a few years ago... Not even used it yet |
HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169 ![]() ![]() |
try peanut butter smoth not rough |
TerryT-J Member Since: 02 Sep 2013 Location: Johnston, Pembrokeshire Posts: 86 ![]() ![]() ![]() |
Or peanut oil. |
Yes still the only one I use it has nano technology and last quite a bit longer than others lol. |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
Then your trim will be eaten by squirrels ![]() |
