Home > Maintenance & Mods (L322) > Maintaining - looking for advice on maintaining L322 plastic
Ed Moses
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
On our L322 Supercharged we have an area of light grey plastic at the bottom of the windscreen. This has dulled with age and I am looking for advice on caring for this. I could use a 'back to black' product but am. It sure that this is the best option.
Regards,
Ed
Post #437403 7th May 2017 8:50pm
wood78987
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
Just done mine this weekend with autoglym tyre gel and the other plastic bits on the car. Looks much better now Thumbs Up 2012 Westminster 4.4 TDV8
Post #437412 7th May 2017 9:22pm
kbald
Anything you use on it will wear off qickly and it will be dull grey again in no time! Gtechniq do a product which is expensive but supposed to be a long term solution to dulled plastics which you may want to look up on google.
Post #437414 7th May 2017 9:22pm
Caddyshack
United Kingdom 2014 Range Rover Autobiography SDV8 Indus Silver
Yes, g technic is the product you need, I think it is c4, you only need a tiny bottle....it is like nothing else I have used before, forget plastic polishes, the g tech properly revives it.
Post #437416 7th May 2017 9:29pm
mzplcg
The main reason that the plastics go grey is because they continue curing with UV light so the oils come to the surface and get washed off. The g-technic stuff works well and I have found that it is much more permanent if you heat the plastic up before applying it - CAREFULLY !!
A paint stripper gun (not a hairdryer) is the tool but don't get it too hot. As it warms the surface will become tacky. This is the time to apply the g-technic as it then bonds permanently with the surface. Like I said, careful use of the heat. Overdo it and the plastic melts. Best done off the car as well so you avoid collateral damage.
The beauty of g-technic is it won't pass UV light so further curing of the plastic is stopped.
Post #437470 8th May 2017 10:19am
buffalo4
2009 Range Rover Vogue SE TDV8 Bournville
Will the heat not deform the panel ?
Post #437484 8th May 2017 11:29am
n1cktdv8
I tried a host of treatments and then saw a chap on another forum using a matt black plastic paint. I have done the same and it looks good. Is this where I put the car details and a bit about myself ?........
Post #437485 8th May 2017 11:40am
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
do mine every couple of washes with Autoglym - Bumper & Trim Gel
brings back the colour very well and actually lasts very well too. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #437489 8th May 2017 11:52am
buffalo4
Any brand Nick ?
Post #437497 8th May 2017 12:42pm
pld118
Bought the Gtechniq stuff a few years ago... Not even used it yet Rolling Eyes
Turtle wax is my tyre and trim gel of choice on the RR as recommended by site sponsor Gary Elliot a long time ago Thumbs Up
http://www.fullfatrr.com/forum/topic18821....turtle+wax
Post #437590 8th May 2017 8:52pm
HGv driver
Wales
try peanut butter smoth not rough
Post #437600 8th May 2017 9:40pm
TerryT-J
Wales 2005 Range Rover Vogue Td6 Java Black
Or peanut oil.
Post #437650 9th May 2017 12:38pm
Yes still the only one I use it has nano technology and last quite a bit longer than others lol.
Post #437651 9th May 2017 12:50pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Then your trim will be eaten by squirrels Laughing
Post #437858 10th May 2017 2:17pm
