Home > General > 3 beeps...?? solved |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
Hi all,
27th Dec 2010 12:42pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
Sure this has been asked before, I think it's either some form of tracker, or if it's almost on the hour, the clock beeping at you to tell you. 2006 Mercedes CLS
27th Dec 2010 12:58pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
did the car come with two black credit card size plastic fobs, this is what the unit in your car is looking for,hence the 3 pips. not found.. V8 facelift Range Rover Autobiography 22" wheels.
27th Dec 2010 2:36pm |
DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148 |
3 pips is telling you it has a Navtrak Tracker and the little plastic fob is in the car and the system is activated. 5 beeps tells you it has the system but it either can't find the card or the system is deactivated.
27th Dec 2010 3:38pm |
def not got any plastic credit card type affair with the car.. Can't recall if it was three beeps but think it was.
27th Dec 2010 6:55pm |
Call Navtrak / Cobra on 08000 719800, give them your registration and explain the issue and they will soon tell you if it has a tracker. |
27th Dec 2010 7:33pm |
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 |
Is your car garage-parked at night? It's not your outside temp warning beeps going off is it??
27th Dec 2010 9:03pm |
My daily "low temp" indicator is a single "bong" rather than a "beep"...
27th Dec 2010 9:10pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1511 |
LOL so true! |
27th Dec 2010 9:19pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Do you press and hold access mode to lock it in? If so you will get as you describe once reaching the predetermined speed. Ian |
27th Dec 2010 9:50pm |
Thanks for all the suggestions folks.
29th Jan 2011 8:47am |
