Home > General > 3 beeps...?? solved
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
3 beeps...?? solved
Hi all,
Had a good read through the manual but still none the wiser why my car beeps at me three times. Usually after a few minutes of driving. Sometimes only 30 seconds of driving. IT seems random to me but perhaps someone here can shed some light for me.?
Thanks Ash
2016 SDV8 AB
Post #43679 27th Dec 2010 12:42pm
M44K TS
Sure this has been asked before, I think it's either some form of tracker, or if it's almost on the hour, the clock beeping at you to tell you. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #43682 27th Dec 2010 12:58pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Navtrac tracker. Google it and call the number.
I think it's £275 to reactivate and a years sub. 15MY SDV8 Vogue SE
Post #43683 27th Dec 2010 1:09pm
daveo
did the car come with two black credit card size plastic fobs, this is what the unit in your car is looking for,hence the 3 pips. not found.. V8 facelift Range Rover Autobiography 22" wheels.
Post #43692 27th Dec 2010 2:36pm
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
3 pips is telling you it has a Navtrak Tracker and the little plastic fob is in the car and the system is activated. 5 beeps tells you it has the system but it either can't find the card or the system is deactivated.
The "card" is about 40mm square and 4mm thick. It is hard black plastic and an occasional flashing LED.
Post #43699 27th Dec 2010 3:38pm
comports
def not got any plastic credit card type affair with the car.. Can't recall if it was three beeps but think it was.
Seems like you pull away from park (in access mode eas) and it's beeping to tell me it's gonna rise (or that's what it seems to me)..?? Ash
2016 SDV8 AB
Post #43723 27th Dec 2010 6:55pm
DeltaC
Call Navtrak / Cobra on 08000 719800, give them your registration and explain the issue and they will soon tell you if it has a tracker.
Post #43726 27th Dec 2010 7:33pm
RRCanuck
Canada 2010 Range Rover Supercharged Supercharged Santorini Black
Is your car garage-parked at night? It's not your outside temp warning beeps going off is it??
mike.
Post #43730 27th Dec 2010 9:03pm
DeltaC
My daily "low temp" indicator is a single "bong" rather than a "beep"...
Its a heart stopper as its the same "bong" as the "your gearbox has gone terminal / the engine has no coolant...."
Post #43731 27th Dec 2010 9:10pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
LOL so true!
Post #43732 27th Dec 2010 9:19pm
T24RES
Do you press and hold access mode to lock it in? If so you will get as you describe once reaching the predetermined speed. Ian
Post #43737 27th Dec 2010 9:50pm
comports
3 Beeps...Solved.!
Thanks for all the suggestions folks.
My mind is at rest now. It is 3 beeps to let me know the hour is approaching (as in time) and a single beep to let me know when the temp gets as low as 3 degrees C..!
Phew... nothing more sinister than that. Ash
2016 SDV8 AB
Post #48059 29th Jan 2011 8:47am
