Home > Technical (L322) > Deployable side steps
Page 3 of 4 <1234>
Glm
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Steps
Hi all,
Got one side working but how would I fine out if they had separate fuses or which are the fuses as I can't seem to see which are the fuse for them ,would it be obviously one of the spare ones but it does not stand out. I have also been told it might need resetting at the dealers on lap top ? Current tdv8 range vogue 07
Post #97748 14th Dec 2011 7:48pm
Jpickie
United Kingdom 2007 Range Rover Vogue SE Supercharged Stornoway Grey
On mine there is only one fuse for the whole system, its the first of the large fuses, F61 30A green fuse on the far right of the fuse box behind the glove compartment. MY2007 S/C - Stornoway / Jet
Post #97863 15th Dec 2011 3:58pm
Decided since it was a nice day for a change that I'd have a go at fitting my deplorable steps today Thumbs Up
First things first, stripped out half the front of the car to get the wiring loom installed. First wire to connect up is the main power connection onto the back of the fuse box under the glove box. Having unplugged the big black plug from the back of the fuse box, "that's funny" I thought, "there's already a big red cable in what is supposed to be an empty slot". Further investigation soon revealed that the car did actually have the loom already in place!!!
All that was missing was the actual steps and the switch in the roof panel. Connected the steps and, nothing, no worky!
Further investigation revealed that the 2 big plugs going into the step ECU had been disconnected! Reconnected these 2 plugs and voila, success!!! Thumbs Up
Why anyone would have done this is beyond me but the long and short of it, is that the steps are now fitted and working great! Bow down
So, if anyone is looking for a completely unused loom and ECU for an upto MY10 car, give me shout and I'm sure there's a deal there to be done Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #420079 29th Dec 2016 8:10pm
Since my CCF nightmare, I've been slowly getting back to normal and 1 thing I've found is that my steps are no longer deploying. The IIDTool sees the RDM ECU, which controls them and looking at the live values, it can see me opening and closing the doors, but no step deployment.
I tried another RDM module and checked all fusses but to no avail.
My question is, has anyone who retrofitted the steps have to do any CCF changes to make them work, as Patrick from Gap and I have been wondering if there's any coding work needing done, that was lost when my CCF was restored. Got - 2017 SDV8 Autobiography in Loire Blue
Post #437353 7th May 2017 3:18pm
do they work on the roof switch... ... - .- -.
Post #437355 7th May 2017 3:27pm
No Stan, they don't Got - 2017 SDV8 Autobiography in Loire Blue
Post #437377 7th May 2017 6:08pm
do a battery reset alan, first little steps.. Wink ... - .- -.
Post #437385 7th May 2017 6:45pm
Already done that Stan Got - 2017 SDV8 Autobiography in Loire Blue
Post #437389 7th May 2017 7:01pm
Confused ... - .- -.
Post #437392 7th May 2017 7:09pm
proser
Have you gone through the process as part of the install to initialise the ECM ??
 Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #437461 8th May 2017 8:10am
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
When connecting the steps for the first time, they need to be put in access mode. You need to keep the DSS button held WHILE you turn the ignition as pictured above. Press the button first and then turn ignition, this should liven them up. Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #437468 8th May 2017 9:09am
Fantastic gents! That sorted it!
Because my car already had all the bits except the steps installed, I didn't have to do that bit, so didn't read it in the install guide.
Many thanks Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #437473 8th May 2017 9:29am
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
Anyone got the 'user manual' for these rather than the install manual as I understand you can lock them open or closed but couldn't see anything on how to do that in the manual and someone suggested that there was an additional amendment of that but can't find it on Topix?
Thanks.
Ian. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #437494 8th May 2017 11:27am
this any good ian,
http://www.fullfatrr.com/forum/topic29459....able+steps ... - .- -.
Post #437527 8th May 2017 2:54pm
ianmacd
Thanks Stan.
I had seen that but was concerned by the person saying it wasn't working for them but will try it.
Post #437545 8th May 2017 4:28pm
Page 3 of 4 <1234>
