![]() | Home > Technical (L322) > Water inside in LM 322 |
FrankN Member Since: 11 Feb 2017 Location: Vellmar, near Kassel, middle Germany Posts: 101 ![]() ![]() ![]() |
Hello friends,
Hey Rik ,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
You can also get a smoke machine, the kind you use for parties and fill the car inside with smoke. I'm sure there will be something on YouTube.
http://www.fullfatrr.com/forum/topic39486.html?highlight=smoke Cheers, Greg
I have find the mistake , in the sun roof, the 4 hoses for the water are dirty and closed, now I must clean it
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
If you clean the sunroof drains, use some Nylon Brush Cutter ( whipper Snipper) line it is flexible and will not damage the tubes., |
Thanks, but I have make it yesterday with the nylon you mean , but it goes inside max 15 cm -20 cm not more , in front the wather is runing out, but backside I don't see it |
Sir_Macadam Member Since: 23 Aug 2015 Location: Lille Posts: 4 ![]() ![]() ![]() |
Hi there,
The water was in the fuse cover and inside in the bottom where all cables going to the backside only water, until now we have until now any mistakes and we can not find them , the most Defekts we have find only from the water who comes by the closed drains
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Guten Tag Frankn, dein Englisch ist besser als unser Deutsch |
Hello merchy, thank you for the video , I have make it like the Video , since this time no water inside
Perfect ! i hope i'll have the same issue ! thanks ! |
