Home > Technical (L322) > Water inside in LM 322
FrankN
Germany 2004 Range Rover Vogue Td6 Bonatti Grey
Hello friends,
at first, my english is not the best Bow down
The LM 322 is a german car left hand drive
my new defekt is water inside on the right side of the car , in front and in the backside from the seats, until under the dashboard (until the red thing ) it was wet
the rust is not from the water, an old metall was inside
after cleaning
on the fresh air box was water, I have see it when I remove this
I`dont know where it come, perhaps from the sun roof ?
The electronic from the rigt side was completely wet, what for electronic is on the rigt side, I have any problems with the electronic since any time.
Regards
Frank
Post #436911 3rd May 2017 4:01pm
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
looks a bit like windscreen leaking to me you could try a dye test and pour over windscreen. you might have to be patient as it could be a tiny leak .or have the windscreen resealed . good luck
Post #436915 3rd May 2017 4:08pm
FrankN
Hey Rik ,
thank you for the tip
Post #436916 3rd May 2017 4:30pm
GGDR
You can also get a smoke machine, the kind you use for parties and fill the car inside with smoke. I'm sure there will be something on YouTube.
. Cheers, Greg
Post #436917 3rd May 2017 4:34pm
GGDR
http://www.fullfatrr.com/forum/topic39486.html?highlight=smoke Cheers, Greg
Post #436927 3rd May 2017 5:02pm
FrankN
I have find the mistake , in the sun roof, the 4 hoses for the water are dirty and closed, now I must clean it
Regards
Frank
Post #437179 5th May 2017 4:08pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
If you clean the sunroof drains, use some Nylon Brush Cutter ( whipper Snipper) line it is flexible and will not damage the tubes.,
Post #437215 6th May 2017 1:16am
FrankN
Thanks, but I have make it yesterday with the nylon you mean , but it goes inside max 15 cm -20 cm not more , in front the wather is runing out, but backside I don't see it
Post #437230 6th May 2017 8:33am
Sir_Macadam
France 2004 Range Rover SE Td6 Zambezi Silver
Hi there,
what was the final end of this leak ?
Post #598855 26th Jun 2021 12:50pm
FrankN
The water was in the fuse cover and inside in the bottom where all cables going to the backside only water, until now we have until now any mistakes and we can not find them , the most Defekts we have find only from the water who comes by the closed drains
Regards
Frank
Post #598863 26th Jun 2021 2:39pm
Merchy
Guten Tag Frankn, dein Englisch ist besser als unser Deutsch Thumbs Up
Vor zehn Jahren habe ich viele Monate in Hamburg gearbeitet, Entschuldigung, mein Deutsch ist nicht so gut
Here is a videos showing the sunroof drains, hope this may help.
Post #598875 26th Jun 2021 6:06pm
FrankN
Hello merchy, thank you for the video , I have make it like the Video , since this time no water inside
Regards
Frank
Post #598876 26th Jun 2021 6:11pm
Sir_Macadam
Sir_Macadam wrote:
Hi there,
Perfect ! i hope i'll have the same issue !
thanks !
Post #598955 27th Jun 2021 9:48pm
