Home > In Car Electronics (L322) > Clock wont stop !
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Clock wont stop !
Hi all, as the title suggests my analogue? clock has started to permanently keep turning (as it does when resetting). This is when engine on and off and is running the battery down overnight, I have done a search to no avail.
Any ideas? Thanks in advance
ps, I also have no idea where the fuses are which doesnt help Whistle
Post #437088 4th May 2017 8:59pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hi Rosco, Have you tried a battery disconnect ? Just today wife came home with the radio stuck on and would not reset with the iid tool, all sorted once the battery was re conected......
Simon
Post #437091 4th May 2017 9:06pm
Rosco
Hi Simon, did try that one, hasnt helped unfortunately, thanks for reply Thumbs Up
Post #437092 4th May 2017 9:11pm
Alfasprint88
New Zealand 2007 Range Rover Supercharged 4.2 SC V8 Java Black
When you watch it do you feel like a time traveller?
Post #437133 5th May 2017 9:16am
not sure which fuse it is Rosco but pulling it resets the clock according to a previous thread...looked in the WM ? ... - .- -.
Post #437134 5th May 2017 9:32am
Rosco
Have found a fuse diagram that indicates fuse 13 in the glove box, will try that one Thumbs Up
Post #437141 5th May 2017 10:30am
Sharky1168
Similar problem
Had a similar thing happen to me, so pulled fuse 13 for a few hours & put the battery on charge. Not sure if the charge helped, but when I put the fuse back in the clock was behaving itself again! Gremlins!! Now that I have replaced the head unit, the clock has a mind of it's own with no way to set it, BUT it doesn't go round like a bat out of hell anymore Current RR L322 TDV8 VOGUE
Past: RR L322 TD6 HSE, Discovery 2. Land Cruiser V8, Saab 9-7x, Nissan Maxima, Ford Granada I, II, III
Post #437236 6th May 2017 11:26am
