![]() | Home > Technical (L322) > oil sump plug leaking |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Believe you are supposed to replace the plug when doing an oil change? 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
only thing is plug threads look ok so I assume threads away in sump .have sent away for new plug to find correct insert |
oh and washer should be replaced should be no need to replace plug |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 ![]() ![]() ![]() |
I had the same problem and I got mine helicoiled last week, it's all sorted but it's not a cheap job. The subframe had to
what did they charge �650 for helicoil job can be done in place surely. a new sump cover can not be as dear as �650 .subframe consists of 4 bolts for diff protector easily removed |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Having my sump replaced (Td6) due to garage over tightening the plug and cracking it. Two quotes so far are �1200 and �1500 all in. Sump is �493 + VAT plus other parts and 7-8 hours labour to fit.
wow mines 4.4 mabe different but still seems a bit dear cant see a sump being so expensive |
I think the issue is access and other parts linking through that part of the engine. Both the quotes were from LR independent specialists, not LR themselves. Tom
with a little research I have came across an oversize sump plug for m12 plug which cuts its own thread . have a look on you tube seems the dogs |
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
What happens to the swarf when it's cut it's way in ? |
The subframe was only part of it, the powersteering was also disconnected along with other parts. New steering oil, engine oil and filter and the Helicoil. Happy with the repair as it looks a top job. A new sump was priced at �900. |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I have the 4.4 V8 petrol and at some point my sump had been stripped and we got around it by using a left over bolt with a built in rubber washer left over from the transmission rebuild.
Bryan N Member Since: 01 Jan 2014 Location: Cambridge Posts: 68 ![]() ![]() ![]() |
Had a similar problem on an XJ40 Jaguar after someone previously over-torqued the sump plug and fractured the threads in the sump. I borrowed a Helicoil tap and insert but due to the restricted horizontal access in-situ I made a hash of tapping the hole so that it was not absolutely 'square' to the surface and consequently would leak slightly despite using the appropriate sealing washer and additional sealants.
I don't see why you couldn't use that, I think the oil feed pipe goes straight to the sump after a couple of bends.
